Why does the passenger window roll down everytime i close the door or lock the car???
Old Dec 4, 2010 | 11:13 PM
itsgroll's Avatar
anwser me that?
Old Dec 5, 2010 | 12:42 AM
onthe3rdday's Avatar
All the way down, or just a couple mm?
Old Dec 5, 2010 | 01:04 AM
WataG's Avatar
I'm guessing he means just a tiny bit....why does it do that!?
Old Dec 5, 2010 | 01:44 AM
G35_Brian's Avatar
if he knew he would fix it.....lol
Old Dec 5, 2010 | 01:49 AM
WataG's Avatar
^haha. I just got my G and noticed the windows roll down a tiny bit and back up when you get out of the car...is it not supposed to do that? lolz...this cars windows are driving me crazy already!!! wtf infiniti! lolol
Old Dec 5, 2010 | 02:12 AM
G35_Brian's Avatar
yea they do that..... idk bout roll down but mine go up so water doesnt leak in the car.
Old Dec 5, 2010 | 02:59 AM
sTeadFasT96's Avatar
If I remember correctly, they're supposed to do that so that air pressure doesn't get built up and push against the windows when you close or open the door. All newer cars/higher brand named cars feature this.
Old Dec 5, 2010 | 03:06 AM
TORETTO's Avatar
It rolls down so it doesn't hit the top door frame. If you open the door, you'll notice its a frameless window. If it didn't roll down, it would smack the top of the door. You don't see that "rolldown" on framed windows, which is on most cars.
Old Dec 5, 2010 | 10:17 AM
Irrelevant's Avatar
This is the correct answer.
Late model Mustangs have the same system.
Old Dec 5, 2010 | 10:49 AM
itsgroll's Avatar
No, I'm not talking about the mm roll up, that's on both sides. I'm talking about just the passenger window. It rolls down about 6inches and stays down!
Old Dec 5, 2010 | 11:50 AM
silver g's Avatar
I know what you are saying...my driver side window does this all the time! Everytime I shut the door the window rolls down about 6 inches. Its annoying!
Old Dec 5, 2010 | 11:54 AM
KSWAY's Avatar
Your window regulator needs to be reset..>>>>>>>http://www.infinitihelp.com/diy/gcou..._procedure.htm
Old Dec 5, 2010 | 11:59 AM
Irrelevant's Avatar
Do a search for "window motor reset". It's a very simple procedure that should fix the issue.
Old Dec 6, 2010 | 11:58 AM
In theory this makes sense, but in practice, it's not gonna happen. I was recently concerned about this when my window motor stopped working. I wound the window all the way up manually and closed the door. Then I disconnected the motor harness. The glass has more than enough clearance!
Old Dec 6, 2010 | 12:03 PM
VatosLocos35's Avatar
my window does the same thing, everytime i open the passenger window it drops down alot and stays down...and if i have the door open the window does not operate at all..i have to have the door closed to make the passenger window close or open...and its not the switch bcus i changed it recently...any ideas? sorry for stealing ur thread OP...
