Sucked up water
Old Dec 25, 2010 | 02:20 PM
BW350GTskyline's Avatar
Well i ran through a flooded zone last year on New years, and my car died, but the most interesting thing was it started up but like the person who posted this said it was bogging with the RPM.. i managed to throw it in reverse and drive home, after that i let the car run and the RPM's returned to normal.. took the intake complete off because i have and injen cold air but to my surprise everything was dry.. what caused this to happen is the exhaust for at the Y-pipe got flooded.. now the next day i went to start my car and nothing would start up.. well long story short.. if everyone takes the battery compartment apart you will see all the major fuses tucked away with the battery... well remove the battery and there is a whole that the manufacture has there for what ever reason but i could see straight through to my garage floor... dried up the battery and fuses never had a problem since.. i also intially checked the oil sump and changed the oil just in case as well but never had a problem since...
Old Dec 30, 2010 | 01:50 AM
iicaspii's Avatar
Well that sucked, good luck
Old Feb 3, 2022 | 05:03 PM
doney91's Avatar
04 infiniti g35 coupe 3.5 auto/ slapstick
Rain got into intake
I have a 04 infiniti g35 coupe 3.5 liter v6 auto/slapstick has Cai I just got the car a couple days ago and for some dumb reason someone before me cut holes into hood and put the mess looking wire in it well its been raining pretty hard and I belive the Cai got wet and sucked up a little water now the car won't Rev above 2500 hundred rpm I drove it home about 3 or 4 miles and worried I've ruined the car it sounds fine but won't Rev above the 2500 rpm what should I do any advice helps thank u
Old Feb 4, 2022 | 09:34 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Sounds like you are stuck in limp mode. The service engine light is probably on, OBD2 scan to see what codes it's throwing.
Get a different hood, the engine bay of modern cars is basically just a bunch of exposed computer components, you MUST have the proper covers (hood, under cover) in place to protect the electronics.
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
G35xdriver04
Nov 7, 2015 08:31 PM
alessandro
Oct 8, 2015 09:29 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
