Bought my G35 on Xmas, problems already!
Old Dec 27, 2010 | 09:55 PM
Mark2K8's Avatar
Damn, I also got my G like 4-5 days ago and its the same 05 a/t 85k miles aero everything you have
driven for about 300 miles but no problems so far *knock on wood*
Hope I dont have those problems you're getting
Old Dec 27, 2010 | 09:58 PM
Project's Avatar
Air compresses when its cold. Causes the tires to lose PSI and the sensor will pop. It should be fine once it warms up.
Old Dec 27, 2010 | 10:14 PM
dumbg35x's Avatar
every car is not the same.. it might happen, it might not. or at a later time.
depend on how the driver drive and how it take care of the car.
congrat on the new car.. the know the feeling.
nicely said.
Old Dec 27, 2010 | 11:36 PM
bigballer8's Avatar
TMPS always comes up for the G. I've driven it cross country and it read low alot of the time. should've trusted it. Turns out one of my tires weren't bolted on tightly. Long story short, it bubbled up and tire blew. I had to run spares from Arizona to CA. At least i made it from Maryland to Arizona with no problems.
Old Dec 27, 2010 | 11:41 PM
Sanshyuum's Avatar
yikes! i hope thats not the case, everything looks okay...
Just take back to the dealer you might need a reset if they put new tires on it. As far as the 19" goes the actually psi should be 35.
They didnt put new tires on it, a sears automotive place did about 15k miles ago.
Old Dec 28, 2010 | 02:27 AM
Byoung's Avatar
for the noise problem check the brakes including the rotors or just take it to the dealer ..i had the same problem but i just took the wheel off and made sure everything was tight and wasnt rubbing.. i also added brake lube to the rear calipers just to insure it wasnt the brakes.. if the noise is still present move to the coils then trobleshoot other areas ..i hope this helps this is just from my experience
Old Dec 28, 2010 | 09:36 AM
culi's Avatar
Check the spare tire. Maybe that one is low.
Old Dec 28, 2010 | 09:53 AM
Kuneff's Avatar
My guess on the TPMS light is that it has nothing to do with the temps... I have never had mine mess up, even when it was below zero F.
I bet the dealer or someone has rotated the tires and never reprogrammed the sensors, or even knew they would need reprogrammed. LF has to stay at the LF and so forth... I had mine reprogrammed at my local Nissan dealer because it was the same way when I purchased it.
I would drive for about 35 miles (25 minutes) or so and the light would come on...
Got them reprogrammed and never had an issue since...
Old Dec 28, 2010 | 12:47 PM
Sanshyuum's Avatar
Well mine came on yesterday right after I turned the car on (I had driven it maybe 60 miles while the car was in my name) and has stayed on since. All the tires are at ~35psi
Old Dec 28, 2010 | 01:45 PM
G35SedanGrn's Avatar
im glad i have an 03 with no tpms, my sisters corolla, and dads FX and sisters boyfriends altima all have tpms and its the most anoying thing out there, 9 out of 10 times it goes off nothing will be wrong.
Old Dec 28, 2010 | 02:32 PM
Kuneff's Avatar
Get it checked... maybe a sensor is bad.
Old Dec 28, 2010 | 06:24 PM
TemjinX2's Avatar
the ringing sound could be a bad wheel bearing. have the shop check it out but its relatively a cheap fix.
Old Dec 28, 2010 | 07:15 PM
axerickson's Avatar
My light stays on constantly after about an hour of driving. Multiple trips to the dealer by the prev owner could not resolve. I bought at 40k and now have 70k. I just live w it.
Old Dec 28, 2010 | 07:22 PM
SamIAm's Avatar
^+1
My TPMS comes on at 35mi exactly. Annoying sometimes, but I got used to it.
Old Dec 29, 2010 | 01:13 AM
  #30
jaketuff's Avatar
My tire had a slow leak... TPMS worked properly. Pumped the Green Slime into the tire and no problems since, not in warmer weather, and not in the recent blizzard over here.
BTW : Michelin DWS did very well in the snow on my coupe. Did not have the "Oh S**T am I going to drift around this turn?" or the good ol, "am I gunna move away from this red light?" feeling.
.02
OUT
