How Do I adjust the hood Latch??
Old Jan 3, 2011 | 12:29 PM
Tikiman12's Avatar
Hello,
My hood has a little rattle when I'm driving. So I went and tugged on it and it moves up and down about 1/8 on a inch making a "clunk" noise. When I'm driving I can see it bobble up and down.
How do I adjust the latch? What bolts do I need to adjust.
Old Jan 3, 2011 | 01:29 PM
Kuneff's Avatar
Lose the bolts that hold the latch to the radiator support, lower the latch down and tighten the bolts back up... Then try it out... again and again...
Old Jan 3, 2011 | 03:49 PM
atmel101's Avatar
nice, did not know that
Old Jan 3, 2011 | 03:53 PM
WhosUrBuddiee's Avatar
Bungie cord and duct tape
Old Jan 4, 2011 | 03:52 AM
andrewstclair's Avatar
i believe there is the lil round rubber bumpers on the corners of the hood that turn in and out to adjust exactly that. if not then look on the rad support all cars have them i am pretty sure
Old Jan 4, 2011 | 09:54 AM
Tikiman12's Avatar
Ok thanks, I'll work on that this weekend.
but the hood lines up perfect, so I dont want to use those and push the hood up too high and make it not line up properly.
However I will try it first and see if it does the trick, since its the simplest option.
Old Jan 4, 2011 | 01:07 PM
dont over adjust them just adjust them slightly to take some of the play out.
Old Jan 4, 2011 | 01:57 PM
Tikiman12's Avatar
alrighty will do. I'll let you know what happens tonight
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Picture Share
Feb 4, 2018 12:41 PM
Fox843
Nov 7, 2015 05:43 PM
hrdwirk1
Oct 2, 2015 06:34 PM
