mpg
Old Jan 23, 2011 | 04:27 AM
  #46
partyman66's Avatar
Originally Posted by ___
Why you using 89 on our cars???
and no its not normal if your using 89, We got V6, we need 91+
Just so you know... the number of pistons a car has and the fact that they are configured in a V, Inline or boxer configuration makes no difference in the octane requirement. The main factor for the fuel octane recommendation is the compression ratio of the motor and whether or not it is using forced induction to increase that ratio during operational situations.
Old Jan 23, 2011 | 09:46 AM
  #47
Irrelevant's Avatar
Originally Posted by N@eem
chevron. always use what the manual says, which is premium, i avg about 22-23 mpg and i drive 700 miles a week 90% hwy. and yes im going to complain about the gas mileage cuz when i bought the car i drove like 75 miles a week, then i moved, so now its time to move on to a new car
I think I'd be as concerned about depreciation when driving 35,000 miles/yr. Any interest in motorcycles? Cheap gas, cheap insurance, minimal depreciation relative to a car...tough to beat - especially if you live in a place like Texas where you can ride most of the year.
Old Jan 23, 2011 | 12:11 PM
  #48
V35 Skyline GT's Avatar
6MT Coupe
Originally Posted by bond10aa13
Anyone know which gas is the best as in shell or chevron. I have heard chevron but curious others opinions.
I use Shell, sometimes Chevron. Only top tier endorsed fuels for me, never bargain-basement with insufficient low standard additives/detergents.
Originally Posted by grocerylist
It all comes from the same refineries.
True, but then different proprietary additives are added after that...or not.
Originally Posted by 4D05G35
+1. But these cars call for 91, so putting 93 in it is also wasting money.
These cars call for 'minimum' 91 not 91 written in stone.
MPG topic:
city/hwy/spirited
30%/65%/5%
~20-22mpg
Old Jan 24, 2011 | 01:27 AM
  #49
Clob's Avatar
I drive with a heavy foot. Mostly highway and I average 21mpg. Not to terrible.
So my last post was to the 1st page. N/e ways, it depends on how you drive. If you have a lead foot, your going to waist gas. If you drive like a granny, you should be pulling close to 20mpg or more. You should be using 91 and not 89. It does make a difference.
+1. The car is just to much fun to worry about MPG. If you want a car with good fuel economy, then get a something else. This is the same reason I don't worry about tire consumption. There are pleny of 1.6l cars out there than do 40mpg. Or a Diesel...
BTW: N/e is the same amount of keystrokes as to just type Any. No offence. Just an observation as I was reading your post.
Old Jan 24, 2011 | 02:43 PM
  #50
julio9817's Avatar
I'm planning on picking up a G35 coupe but ****, i didn't know these cars were that much of a gas killer.
Old Jan 24, 2011 | 04:42 PM
  #51
juan350gt's Avatar
It just depends on how you drive i drive decent monday-friday weekends i haul *** sometimes. When i am on the FWY ,i ususally drive 70mph on 6th gear and get 34 to 35mpg no lie on stillen exhaust,intake and ground kit i'lll post a pick from my navigation system,Remember not all have the same driving styles.On the streets is were i hurt abit with 23mpg..If you have a heavy foot take those weights off and drive less hard,Put 91octane as well cause if you add cheap gas it may cause a pre-eruption of the piston rings and you will need a new engine,That was said from my friend who is a tech at Nissan infiniti as well.Follow those recommendations for gas.
Old Jan 24, 2011 | 04:47 PM
  #52
Blackout713's Avatar
go fill up with 91. at a minimum. going lower octane will increase the chance of a "knock" or detonation event in the engine's bottom end
Old Jan 24, 2011 | 05:06 PM
  #53
nismoz's Avatar
91+ octane is required since anything lower will cause engine knocking and misfire. So if you dont have 91 in your area, then 93 is the only thing you can use. Using 89 in order to save a few cent isn't worth it.
I get around 14-16MPG city driving. And i get around 18-20 highway driving at mostly 80 MPH. My MPG seems low because I got 9.5" front rims and 10.5" rear rims. And the tires are 245 fronts and 275 rears. So they are bigger compare to stock, they will stick to the road more => drop in MPG. Performance parts will also decrease MPG.
Old Jan 24, 2011 | 08:45 PM
  #54
julio9817's Avatar
doesnt a CAI increase your mpg? or so ive heard...
Old Jan 24, 2011 | 10:38 PM
  #55
nicbaines's Avatar
false…. most of the time
it usually only gets you heat soak and loss in mpg…
in rare cases CAI can be well constructed but rare. stock with drop in filter is usually the way to go.
Old Jan 25, 2011 | 12:22 AM
  #56
arth91's Avatar
Well said... I was looking through the pages of this hoping someone posted something like this...
It's all compression... higher octane makes your gas more stable at higher pressures. Use 91 minimum. The engineers aren't stupid. They don’t put that on there for fun. Any higher grade will give you no benefits unless you are adding extra compression. It would be a waste of moneys.
Old Jan 25, 2011 | 10:27 AM
  #57
SofaKingG's Avatar
Originally Posted by fstasfk_G
i wasnt complainin about gas, i was jst seein if others are the same, if not, then i gota get it checked out. so check urself before u start to get smart
Keyboard gangster hahahahaahahha
Old Jan 28, 2011 | 06:47 AM
  #58
Papa_D73's Avatar
Sorry If this isnt the best place to post this but I searched and couldnt find an answer.
Here is my question. About six months ago I finally put a Z-tube and JWT intake on my 05 Sedan. The first few weeks my MPG went up to 24.3. I took it in to the dealer for its 100K work and since then my MPG has steadily gone down. I am not at 18.7. I reset the ECU about a month ago and the power is back but and I expected my MPG to go down a little but was hoping I would rebound a little to where I was. Could the Dealership do a little something to screw up my MPG since they boldly told me they didnt like the fact I changed the intake? BTW I now take my G to a different dealer... Thanks for any advice in advanced.
Old Jan 28, 2011 | 10:56 AM
  #59
cubs4worldseris's Avatar
I get about 21 MPG (city and highway combined).
Old Jan 30, 2011 | 09:19 PM
  #60
Spode's Avatar
wow seriously.
Idk what it is but i get at least 24MPG every time i fill up.
I live in Northern DFW.
on a good tank without me doing any spirited driving i'll get 400 Miles at least.
an average tank it's 325-350 Miles.
