Oil/Gas leak
Old Jan 27, 2011 | 01:41 PM
DaD_e671's Avatar
Oil/Gas leak
Was wondering if anyone has or has had this issue. Its really odd because I had my car parked for the past 3 days. I noticed that its has been dripping oil/gas right behind the driver side door under the car. I'm in awww because I don't know what may be causing that and also since I bought the car there has always been a pretty strong gas gas on the driver side.
Any idea fella's? Anything would help Thanks...
Old Jan 30, 2011 | 07:36 PM
needforspeed's Avatar
oil leak
sorry that u r going thru issues with ur G, but im having same issue with oil leak on driver side. few days ago i can smell oil burning after i drove my car harder than usual. i took the G to jiffy lube where i get my oil chage, so they can look under the car. we were able to see oil under the car, but couldn't trace where it was leaking from. hope we can get directions from the experts. GL
Old Jan 30, 2011 | 08:52 PM
the_sedan's Avatar
your fuel pump is on the passenger side as are the fuel lines......unless you have a leak from your gas tank somewhere?
Old Jan 30, 2011 | 11:24 PM
BW350GTskyline's Avatar
I had a mysterious oil pool on the driver side of the front cross member that i could not trace back.. I was changing my oil and i couldnt help but notice this on the front cross member so
Old Jan 31, 2011 | 08:52 PM
the_sedan's Avatar
could only be a valve cover gasket leak or a power steering leak.....
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
KallDay86
Jan 8, 2016 12:42 AM
hrdwirk1
Oct 2, 2015 06:34 PM
NyCrAzY
Oct 1, 2015 09:19 AM
vamarris
Sep 26, 2015 12:56 PM
