excessive oil consumption
Old Nov 5, 2004 | 02:33 PM
Q45tech's Avatar
Re: excessive oil consumption
Please understand I don't work for Nissan or any automotive dealer. Tech is short for Technical ------- the name I've used for the passed 8 years on INET.
I do have an affilation [business operations consultant] with a group of independent companies that repair Lexus and Infiniti models but that is it.
Just owned an Infiniti since 1990.
If you think about it one bad engine per 1,000 G sold is $8,000/1000= $8 extra in warranty expense per car sold is high but not terrible..........now 1 in 100/50 could get expensive.
Since it comes out of the profit column.
Old Nov 6, 2004 | 04:35 AM
skeleton_cru's Avatar
Sedan
Yours is not an isolated incident. Some of the VQ engines have had issues with oil consumption. I actually had engine failure from it. Fortunately after A LOT of B.S., Infiniti replaced my engine under warranty. See the thread here:
https://g35driver.com/forums/showfla...sed&sb=5&part=
To omahag, no I didn't hammer on it during the break in period. I work way too hard to afford a G then to abuse it.
Old Nov 6, 2004 | 12:46 PM
juggernaut's Avatar
i am not that handy when it comes to checking consumption levels...is it safe to say if my "check engine " light doesnt trip...i am okay?
Old Nov 6, 2004 | 01:02 PM
P_Diddy's Avatar
To all those with excessive oil consumption, please tell us if you broke your car in (no WOT, kept it <4k RPM, varied speeds, etc) and for what mileage you did this for.
2004.5 6MT DG/G Coupe | Premium | Aero Kit | ClearBra | See profile for pix
Old Nov 6, 2004 | 02:42 PM
Z06ified's Avatar
You shouldn't rely on the low oil warning light. Check it on the dipstick yourself periodically. If you're not familiar with your car's oil burning habits, check it about every 500 miles, or about once every other fuel fillup. Once you learn what it typically uses, you can check it at the interval you think it might get a bit low. See your owner's manual if you're not sure how to check your oil.
2003 G35C, 6MT, DG/G, Aero/Nav/Premium
2002 Corvette Z06, Electron Blue/Black, headers, intake, exhaust, 380 rwhp
Old Nov 6, 2004 | 03:00 PM
pointman1's Avatar
cool, thanks for letting me know... but for ideal situations shouldnt the level remain almost exactly the same?
Old Nov 6, 2004 | 04:10 PM
Z06ified's Avatar
Not necessarily. Its normal for some engines to burn oil. As long as its not excessive, its fine. Usually, excessive oil burning is deemed to be more than a quart per 1,000 miles.
Some engines don't burn any oil (like mine), but some burn a bit, so that's why it needs to be checked.
Oil level is critical to maintaining proper oil pressure. The oil is the lifeblood of your engine. Think of what happens if your body runs low on blood and blood pressure - you can die quickly. Same thing with your engine and its oil. It's no less important to check your oil periodically as it is to make sure you have gas in the tank.
Old Nov 6, 2004 | 05:43 PM
Sedan
<hr></blockquote>
NO, that is NOT safe to say. DO NOT rely on your oil light. I was driving 3.5 quarts low and I only saw the oil light come on once for a brief second when I stopped hard at a traffic light.
Old Nov 6, 2004 | 05:47 PM
Sedan
<hr></blockquote>
During the break-in period, when I first bought my car, I kept the RPM's under 3k and tried to vary my speed on the highway for 1,200 miles.
I am doing the same with my new engine.
Old Nov 6, 2004 | 06:16 PM
bocatrip's Avatar
After reading this thread I decided to check my oil. I have never checked my oil other than after my first oil change with synthetic at 3700 miles to make sure it was full at that oil change. I now have 7300 miles and just checked it. It's absolutely full. I am not an agressive driver and I guess I'm one of the lucky ones.
2004 G35C/IvoryPearl/Graphite/5AT/Premium/Clear Bra
Old Nov 6, 2004 | 07:06 PM
ARH_twilightblue's Avatar
I don't know if I'm also "one of the lucky ones" or what but my car has been reading the exact same level on the dipstick for about 2700 miles. I broke it in by accelerating hard for a second or two then letting it run below 2k rpm for at least 5 mins. This is to let the engine cool as localized heat buildup (as in the bearings) is not read by the temp. gauge. I repeated this many times to make sure the rings seated properly. I even hit the rev limiter at 1000 miles with light load on the engine (~ half throttle) to expose it to its operating range. I don't know if this is right or not but I hope I never burn any oil :P
04.5 TwilightBlue Coupe 5AT//Willow Leather//Premium Pkg//Perf. Tire & Wheel Pkg//Sunroof//Splash Guards//Sirius Sat Radio
Old Nov 7, 2004 | 12:09 AM
pointman1's Avatar
thanks guys for all the help... im finally well equipped to fight this thing...now ive gotta keep my fingers crossed as i check the oil.
thanks again.
Old Nov 9, 2004 | 04:15 PM
himike's Avatar
i followed all manufacturer guidelines for break in and maintenance. i also am not an aggressive driver , my car is completely stock and i have never used synthetic oil. the car is now at the dealer...though i am not optimistic....this problem also didn't become apparent until 17k miles or so..
this may be similar to a problem that bmw had with m3's a while back (a friend bought one) for certain production dates, there were higher incidences of engines eating themselves. the user groups were charting all incidences of engine failures as a function of production date
Old Nov 9, 2004 | 06:25 PM
I wonder if this is the case with the G35's? Maybe there's a link between the VINs of cars that have consumption, or maybe it's random (?)
Old Nov 9, 2004 | 07:04 PM
  #30
G35CFan's Avatar
Got my 6MT coupe in March '03. 46K miles. Switched to Mobil-1 Syn at 15K miles. 4300 miles on the current oil, and it looks like I'm down a quarter of a quart.
