Doors Won't Lock on My '03 Coupe
Old Feb 3, 2011 | 11:44 AM
nicker's Avatar
When I use the key fob to lock the doors the horn honks, lights flash like they should. The doors make a clicking sound but neither of them actually lock. Same thing happens from the inside: If you hit the lock button on the door, you hear a click sound but nothing happens. So I have to lock the doors manually from the inside and put my key in the driver door to unlock the car when getting in it.
I'm a noob, just got my G a couple days ago, and had a Jeep Wrangler before this so I'm used to manual everything so I don't know much about this issue.. haha but does anyone know what is causing this problem?
Thanks!
Old Feb 3, 2011 | 12:30 PM
TannerG's Avatar
Door lock actuators are bad. Search for it.
Old Feb 3, 2011 | 12:39 PM
wbama387's Avatar
Yep it's the actuators and they aren't cheap.
Old Feb 3, 2011 | 01:49 PM
TannerG's Avatar
take a look at these:
https://g35driver.com/forums/interio...=lock+actuator
Old Feb 4, 2011 | 09:51 AM
sykoenigma's Avatar
congrats on the car, i'd bring it in for inspection to make sure any of the other small things aren't wrong on this car since it's new. issues pop up all the time, and even the smallest thing can be a big problem
Old Feb 5, 2011 | 12:59 AM
Tabris's Avatar
Off chance.. I've had this happen before when my last passenger shut the door, but not hard enough for the window to slide all the way up. If you try to lock the doors, they lock and then immediately unlock. It's worth a quick try, just shut both doors snugly.
mike730
Jan 12, 2018 04:25 PM
xluke
Jul 30, 2016 01:48 PM
will091195
Jul 27, 2015 09:19 PM
apintojr
Jul 23, 2015 10:52 AM
