Have you checked your throttle body? It may be dirty.
It is normal for the engine to drop a little below idle rpm and go back up to where it should be after revving, but not as much as you described. A dirty throttle body can cause it to drop a little too much. In extreme cases, the engine might even stall.
kinda like what he said. it seems like your engine is suffocating a little bit with not enough air. you should check your air filter or try doing it without it to see if that might be the problem.
I'm gonna try that this week. I'll let you know the result. Thanks!
