02 Sensor?
Old Feb 13, 2011 | 08:26 PM
VQ Johnny's Avatar
02 Sensor?
Do both banks use the same sensor or are they 2 different part# (post cat). After looking on courtesyparts.com I'm slightly confused, see links.
This one bank 2 sensor 2
http://www.courtesyparts.com/22690na...8-p-13712.html
And this Bank 1, Sensor 2 and/or Bank 1, Sensor 1 (I think sensor 1 is a typo)
http://www.courtesyparts.com/22690n-...4_715_743_747&
Also when I looked at autozone the bosch sensors are different parts for each side with one being more expensive. Any incite would be helpful.
Old Feb 14, 2011 | 05:36 AM
Tricky-Ricky's Avatar
With the earlier 350Z and Infiniti G35 the two front and two rear O2 sensors are different part numbers, however i am not sure if they are actually different sensors, although i suspect they are, the rear (cat) sensors are basically there to monitor cat function and whether they supply an extended frequency signal or are just monitored differently by the ECU I'm not sure.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
KallDay86
Jan 8, 2016 12:42 AM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
vamarris
Sep 26, 2015 12:56 PM
sullivan72
Sep 22, 2015 11:39 PM
