Replaced CAM/CRANK/MAF Sensors - Still issues!
Old Feb 16, 2011 | 05:57 PM
brenty_blanco's Avatar
Hey guys, I've read through about 30 related topics, but non really answered what I'm looking for.. Sorry if this is in the wrong section, but I need serious help.
My '05 coupe was having many similar problems as other people on here and my350z. CEL, VCD, and Slip lights coming on, starting and shutting off (while driving).
I went ahead and replaced the MAF sensor, then CRANKSHAFT sensor, and just today the passenger side CAM sensor.
With new MAF sensor, it wouldn't start on first try, but always on 2nd. Would run, but then die shortly after.
With new Crankshaft sensor, same 2nd start thing, but would stay running, although car felt heavy and struggled where it usually didn't.
10 minutes ago replaced the CAM sensor located on the passenger side and now car will turnover, stay on for a second, then die.
I'm getting ready to call a tow truck and get her sent over to Infiniti, so they can bend me over
ANY help would be greatly appreciated.
Old Feb 16, 2011 | 06:08 PM
KSWAY's Avatar
Check and make sure your intake filter is clean.
Mine did the same thing until I cleaned my K&N filter and MAF sensor, Hasn't done it since..Just a thought..
Old Feb 16, 2011 | 06:13 PM
Just installed brand new AEM coi a few days ago..but checking over it all again. Thanks for the suggestion!
Old Feb 16, 2011 | 06:19 PM
superchargedg's Avatar
What code is it setting and is the cel on
Old Feb 16, 2011 | 06:21 PM
Had the P0355 code, replaced the CAM & CRANK sensors, threw same code after clearing them. And YES, cel is on. Along with VCD & Slip light again
Old Feb 16, 2011 | 06:58 PM
Tricky-Ricky's Avatar
If its still throwing a CEL and CAS code after replacement, have you checked the wiring harness for the sensor?
The fact that it dies just after starting could also relate to a fuel system fault.
Old May 21, 2012 | 09:19 AM
PEARL-G's Avatar
Have you solved the problem?
Hasanbaloch
Feb 29, 2024 08:45 PM
Muski_G
Dec 1, 2023 11:11 AM
newg37
Jul 26, 2015 09:32 AM
stay_tuned
Jul 21, 2015 07:09 PM
igking
Jul 19, 2015 01:12 AM
