Help..I lost my side marker and full harness only wires exposed
Old Mar 9, 2011 | 10:45 AM
Herles(Jersey)'s Avatar
Need some advice.
I hit a plastic bottle in the raod, dont aske me how, but it flew up, knocked my clear corner out, and the whole wiring harness. I just have the wires hanging out now. The problem I have is finding a wiring harness that I can plug into a new light assembly and clear corner.
Any one know how I can do this? or find a wiring harness I can splice or solder back in so I can order a new side light?
Old Mar 9, 2011 | 03:01 PM
NuttinButtaG's Avatar
ouch that sux. wish i could help but dont know how
Old Mar 9, 2011 | 05:26 PM
Kuneff's Avatar
You gotta find a used one. I didn't have any luck getting a new one. Also, you can get a universal pig tail from any Parts store like NAPA or Advance.
Old Mar 9, 2011 | 06:34 PM
gary c's Avatar
Find a Infiniti/Nissan wrecking yard in your area and just buy what you need, don't forget to take wire cutters with you.
Gary
Old Mar 9, 2011 | 06:59 PM
jibberjabbers's Avatar
Find a junk yard. Good luck getting a new one. Dealership wanted I think 1000+ for a new wiring harness, when some ricer stole my stock corner and the wiring harness connected to it.
Lucky for me, some guy at the service department hooked me up for free.
I say search the yellowpages for wrecking yards and call around to see if they have them laying around or any G35's sitting there.
Old Sep 1, 2011 | 03:23 PM
6MTG354ME's Avatar
Figure I would post the solution for everyone who have come across this. I had some huge blown out tire from truck land in front of my car, and blew out the passenger liner, side marker, socket, plug etc. Just had the bare wires exposed. Dealer telling me I need $1,000 wiring harness.
On my 2004 G35 Coupe, the license plate lights use the same socket and bulbs in the lens as the side marker. They sell a plug that goes into those. Its $12.
I made this diagram:
Old Sep 1, 2011 | 05:02 PM
psycobusa's Avatar
good find, just buy the license plate light harness and cut off the part you need and splice it on the side marker wires.
Old Sep 1, 2011 | 05:46 PM
6MTG354ME's Avatar
Precisely. Does anyone know which is anode and which is cathode? I can use a tester to find the hot wire, but not sure if if the order matters on how I connect it to the plug.
Old Sep 6, 2011 | 01:24 AM
andrewstclair's Avatar
it doesn't matter at all which way you connect it. if your using LED marker lights then put em in and if they dont work pull it out n turn it around and itll work that way
Old Jul 18, 2021 | 08:12 AM
elainelorie's Avatar
infiniti g35 DE coupe
i don’t know if you’re still active, but for some reason, I can’t see the diagram? I don’t know if you could pm it to me or something
Old Jul 19, 2021 | 03:56 PM
LoSt180's Avatar
You just order the license plate sub-harness, part number: 26251-AM800
That will give you two ends to cut off and splice in for the side markers. You can image search that part number, but it's pretty obvious when you have it in your hand.
jsimonk
Dec 22, 2023 03:49 PM
wonderizm
Sep 24, 2015 03:09 AM
realtalk21
Jul 20, 2015 09:07 AM
wylin
Lights
Jul 18, 2015 06:12 PM
