Front wheel hub replacement, I have 2 options?
Old Mar 10, 2011 | 10:34 PM
2one8's Avatar
I need to replace the front right wheel bearing. While searching for them I came across two options, with and without stability control. Now I've always been under the impression that VDC and stability control are two different things, so I'm not sure which hub to get...
http://www.autopartswarehouse.com/se...tt=Wheel%20Hub
Old Mar 11, 2011 | 12:35 AM
Jg35skyline's Avatar
You may not need a bearing check your front tires they may need a balance
Old Mar 11, 2011 | 08:19 AM
2one8's Avatar
I've already checked everything, I know it is a bearing.
Old Mar 11, 2011 | 09:41 PM
AuAltima3.5's Avatar
I think certain 350z models lacked vdc, though I could be wrong.
Why not get it from another place? The link above gave me 2500+ choices for bearings.
If you are set on this supplier, call them and ask.
Old Mar 12, 2011 | 01:04 AM
2one8's Avatar
Thats the link I got from a DIY writeup on my350Z, havent dug into other sites much yet cuz I havent been home.
Old Mar 12, 2011 | 05:49 PM
toro12's Avatar
20 Year Member
Either way, VDC or stability control your talking about front hubs manufactured to fit a front wheel speed sensor.
Sounds as if you need to call the supplier and get them to point you in the right direction.
Before that call:
1st look at your existing hub for the black "cabled" wheel speed sensor and how it fits the left and right hubs. The wheel speed sensor fits in a bored hole and it's small bracket is bolted in to threaded holes in the hub.
rezendvous420
May 31, 2020 01:26 PM
Xfactor
Dec 1, 2019 12:52 PM
teamghost
Jul 28, 2015 04:52 PM
rping
Jul 26, 2015 09:53 PM
TheefrshstVQ
Jul 26, 2015 09:37 PM
