Slip, engine soon, VDC light ON
Old Mar 12, 2011 | 08:13 PM
criTix's Avatar
The other day out of no where the service engine soon, vdc, and slip light came on. The car has stalled out two times since yesterday drove fine, but today had trouble starting. The only thing that has been done to it is change my rotor and pads brake!
What could be wrong?
Old Mar 12, 2011 | 08:15 PM
WhosRich's Avatar
Been discussed many times, but I'll try to help you out. Did you check the brake fluid?
Old Mar 12, 2011 | 08:53 PM
the_sedan's Avatar
cam sensors
Old Mar 13, 2011 | 01:08 PM
criTix's Avatar
Brake Fluid is on High !
You guys think it maybe cam sensos ?
Old Mar 13, 2011 | 02:20 PM
1SiccG's Avatar
You know mine did that to me the other day. I ended up doin a battery change and problem solved =)
Old Mar 13, 2011 | 02:42 PM
criTix's Avatar
i already tried.
When the lights are on (VDC + Slip + Engine soon) .. i have some starting problems (5 seconds before starting). The light dissapear (VDC + SLIP) sometimes when i turn off the car... When lights off, no problem to start.
I read the forum and i saw many other whit this problem.
Should i go for camshaft sensor replacement ?
thx for your help !
Old Mar 13, 2011 | 06:11 PM
Blue Dream's Avatar
I drove ttrank's car solo
Is your SES light on? You need to have a code reader hooked up to your OBD2 port to pinpoint the particular issue. Otherwise you're grasping at straws trying to figure it out. Many auto parts stores will pull codes for you for free. Get those and come back here for more guidance.
Old Mar 13, 2011 | 11:27 PM
g-cia35's Avatar
I had the same thing happen to me 2 yrs ago and my car ran like dookie.. I had the stealership change the cam sensors and my car ran good as new..
Old Mar 13, 2011 | 11:43 PM
nissandrifter32's Avatar
Good luck solving the problem..
Old Mar 13, 2011 | 11:56 PM
coupetech's Avatar
those lights all come on together when something from either system (engine - ABS/VDC/SLIP) that communicate w/ each other thru lan/can trips an error code. ie; Engine misfire makes engine code trip then ABS unit cannot read proper engine speed OR low battery voltage trips code for low voltage in ABS control unit, etc etc. There are several things that can make all these codes trip at once and should be scanned with the Consult3 scan tool and properly diagnosed by the dealer. otherwise you wind up w/ mis-diagnosis and wasted$
Old Mar 15, 2011 | 05:46 PM
criTix's Avatar
Got a scanner test:
Code : p0340, p0327, c1109
Thx for your help !
Old Mar 16, 2011 | 05:12 PM
criTix's Avatar
Should I change my 2 sensors (bank 1 and bank2)?
Thank you
Old Mar 16, 2011 | 10:27 PM
coupetech's Avatar
yes both banks, if you do it at the dealer have them reset the 'Self learn' on the ecu also
Old Mar 16, 2011 | 10:31 PM
jsmith29's Avatar
when this happened to me in december, it was the bank 1 cam sensor.
I would run the codes before having both replaced.
Old Mar 16, 2011 | 11:40 PM
coupetech's Avatar
you should change cam sensors in the pair b/c they usually get sludged up, ran dry of oil/overheated at similar times. Save yourself $ and time in the big picture cause when one goes the other one is close behind
