Rear Rattle Problem (interior)
Old Mar 14, 2011 | 01:23 PM
Goldendragoon's Avatar
Hello,
I have been experiencing a rattle/creak/moan from the rear of my vehicle. I am under the impression the noise is only audible inside the vehicle. It doesn't have to do with the doors. I think it might be the rear seat, backrest, or deck. I have reclining seat backs in the rear. I stumbled on some good guides to taking apart the rear seat to check bolts as well as the rear deck to add foam to reduce rattle about 6 months ago, but am no longer able to locate them. Can anyone help with some advice or links to these guides? I am having trouble finding them.
Old Mar 14, 2011 | 01:39 PM
anynigma's Avatar
Athens Blue G35 Coupe 6MT
Do a search for "Rear Deck Rattle" I think thats what they call it. There might even be a TSB out for this, so Infiniti might take care of it for you.
Old Mar 14, 2011 | 02:26 PM
gary c's Avatar
I only have one rattle that aggravates me, that's the handle on the passengers seat that tilts it back. It doesn't do it all the time just when the seat is in a specific position....super glue will fix it!
Gary
Old Mar 14, 2011 | 02:28 PM
anynigma's Avatar
I've never been in an 04...there's a tilt handle on the door??
Old Mar 14, 2011 | 08:12 PM
Its an 05. The handle is on the seat. I will keep an eye on the lever to see if that is what is making the noise. I will let you know what I find out.
Old Mar 14, 2011 | 08:18 PM
rcdash's Avatar
Do you have aftermarket shocks? If so, there is a nice write up on my350z for fixing it.
Old Mar 14, 2011 | 08:34 PM
apologize for not explaining it in my original post my g 35 is 100 percent original
Old Mar 14, 2011 | 09:19 PM
cpufreak3's Avatar
I had a rear deck rattle. Put a foam weather strip there, problem solved.
Old Mar 14, 2011 | 10:41 PM
Did you have to remove the deck to put it in?
Old Mar 14, 2011 | 10:43 PM
Frankieg35's Avatar
I have the rear deck rattle from my system.. It sounds horrible.. Im to lazy to fix it.. lol
Old Mar 15, 2011 | 01:38 AM
andrewstclair's Avatar
mine rattles from the headliner right in the middle of the rear window
Old Mar 15, 2011 | 04:02 AM
Affalterbach's Avatar
Mine does this with the stock BOSE system as well, not too noticeable tho.
mike730
Jan 12, 2018 04:25 PM
tiguy99
Mar 1, 2016 11:42 AM
kinetek
Aug 3, 2015 04:25 PM
Frostbite91
Aug 2, 2015 04:59 PM
atk08
Jul 30, 2015 03:12 PM
