Quote:
I've seen the timing chain tensioner cover (across from the water pump cover) and it looks easy to access. Am I wrong? If anyone can tell me if I just have to drain the oil, loosen/remove the drive/ac belts, and remove the tensioner, please confirm. Or do I just follow the FSM? I read the FSM and it only has the timing chain cover disassembly and not just the timing chain tensioner cover. If there is way more to it, then I'd love the feedback.
I've been told it is a bad lifter, but if it was a bad lifter, wouldn't I experience a loss of power? I have zero loss of power, just annoying tick at idle, and the tick increases with rpm increase. Seems pretty common on these G35 coupes as I've read.
https://g35driver.com/forums/engine-...ml#post5676709
your wish is my command Originally Posted by vqde2004
I have a feeling that my timing chain tensioner is worn out and causing my engine to "chain slap." I currently have 173k miles on my G35, I drive 140 miles a day, 700 miles a week, about 40k a year. I've fed this car nothing, but M1 extended synthetic oil. I've seen the timing chain tensioner cover (across from the water pump cover) and it looks easy to access. Am I wrong? If anyone can tell me if I just have to drain the oil, loosen/remove the drive/ac belts, and remove the tensioner, please confirm. Or do I just follow the FSM? I read the FSM and it only has the timing chain cover disassembly and not just the timing chain tensioner cover. If there is way more to it, then I'd love the feedback.
https://g35driver.com/forums/6726350-post312.html
nice diy!Originally Posted by bythabay
hey guys my car had a tick tick noise only when i accelerated and all of a sudden it turned off and it wont turn over at all you guys think it might be the timing chain or pistons being bad please help.... thanks
Quote:
Putting a used engine may result in same problem, just saying. The money you spend on used engine and installation,you could probably fix the issue. Just saying,weigh the options and the odds a used engine with 100k + miles could have same issues in short period of time. You know what maintenance and repairs have been done to your engine,where you don't know what has or has not been done on used engine. That's just my opinion.Originally Posted by dineth00i30
Oh wow, my car has been ticking too and couple ppl told me its the lifters. But if you guys are spending over $1000, I might as well put a used motor in mine.
