G35 Front Wheel Hub Bearing Troubleshooting
Old Mar 24, 2011 | 07:48 PM
Lisalicious's Avatar
I am trying to figure out which front bearing need to be replace Left or Right.
There is humming noise when going straight and turning left but noise goes away when I turn right.
Did anyone have the same problem?
Old Mar 24, 2011 | 08:21 PM
KSWAY's Avatar
you can determine which wheel it is by steering the car left and right as you travel. Steering the car left causes the weight to shift to the opposite (right) side and vice versa. So if the noise gets louder when you turn right, the left side bearing is worn out...louder when you turn left, the right side is worn out.
Old Mar 24, 2011 | 09:07 PM
ldg870's Avatar
You can jack up the car. Firmly hold the tire at 12 and 6 o'clock and give it a good wobble. You can't miss a bad bearing. You can feel and hear it.
Old Mar 24, 2011 | 09:09 PM
WhosRich's Avatar
Member since 2005 and and only 4 posts?
rezendvous420
May 31, 2020 01:26 PM
teamghost
Jul 28, 2015 04:52 PM
cyrus32
Jul 18, 2015 06:22 PM
papo020
Jul 17, 2015 10:30 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
