Buffer gone bad HELP pictures inside
Old Mar 30, 2011 | 12:14 PM
TofuProductions's Avatar
Exactly what Blue Dream said. I'm not expert but I know to never apply wax in direct sunlight, heat, or cold temperatures.
I'm sure most of you all know if you're doing a full detail you should do the wash/rinse, clay, degreaser, and paint correct before the buffing.. That's just what I gather from reading a few detailing threads..
Hope the pad your buddy was using was the right one and was clean too. Good luck man.
Old Mar 30, 2011 | 12:26 PM
Silencer_0's Avatar
^ Good point, maybe they used a soiled pad with dried wax/polish.
Ouch. What pad and wax was your buddy using? Have you tried polishing it? It has to have something to do with the wax..
Old Mar 30, 2011 | 12:33 PM
thescreensavers's Avatar
Mr.202?
OP it looks from the pictures that paint was removed. Can you feel a dip or a raised or flat when you run your finger over it.
What buffer did he use? If its anything under 100 bucks its crap and does nothing.
If its something raised on top of your paint his buffer pad was contaminated with some other crap, or he cause what ever wax polish you applied to super dry to your finish.
oh not to mention, you are suppose to move at a slow 1 inch per sec movment,(you can move a bit faster but). If you do anything to fast you are not polishing your car, you are making it worse. Who ever did this is a noob and car detailing. Dont let him touch your car again lol
Old Mar 30, 2011 | 12:35 PM
Neal376's Avatar
The pictures are not good enough quality to tell but it kind of appears as if he had some dirt on the pad when he was working the polish and scratched the hood as a result. If thats the case, then you will have to wetsand/re-polish the hood back to its original state (and go to someone different). was he using a clean foam pad or a wool pad?
If these are scratches, you would be able to feel the scratch with your finger nails. if it went down to the primer (the first gen g35 primer is off-white/beige color) then a repaint is needed.
wax is applied, you dont need a rotary or a DA polisher. a cleaner wax, on the otherhand, has polish in it and requires some effort.
if you guys are actually "working" to apply a wax, then you either need to clay or polish your car to a smooth surface or dilute your wax appropriately.
Old Mar 30, 2011 | 12:43 PM
Mr.202?
if you look up videos which people who do is faster have a rotary but its not for noobs you can burn your paint. And the first time you use one you probably will.
Noobs like I am and you need a Dual Action Polisher, PC 7424 or Meguiars G110 which cannot burn your paint. Check a 8:30 he is going a little too fast but thats how a polishing process goes.
Old Mar 30, 2011 | 12:48 PM
Neal376's Avatar
l
the 30 dollar rotaries i have used at harbor freight are just as powerful as the dewalt rotary. same goes for the 15 dollar chinese dual action polishers. the difference in price is made up by dewalts and porter cables reliability and longevity. the no-name pieces feel like they will break if you drop em'
eksigned's Avatar
that doesn't look too bad. they're only small scuff marks. *BREATHE*
use a mild compound to get that stuff out. it's NOT permanent. what kind of "buffer wheel" was he using? start from the beginning. use something to clean the car (strip all wax, etc.), clay, tape off, then start polishing. if polish doesn't work (i use optimum products) doesn't work, move up to medium compound. if that doesn't work, throw on some compound (do in very small portions). good luck!
Old Mar 30, 2011 | 12:58 PM
Neal376's Avatar
+1
if they are indeed light scuffs. you can save some time and take it a step furthur by wetsanding.. if you dont want to wetstand, you can still remove the scratches by using polishing for a longer time + using more elbow greese.
2000 grit wet sandpaper, soaked in water and soap. mask off the area and sand in one direction. dry after each wipe and stop once the entire surface is even and dull. whip out a polish of your choice and start rubbing away until the surface is nice and glossy again. clean the surface, and wax. done.
any polish would be good. a meguires product is easy to work with and easy find at any auto store.
Old Mar 30, 2011 | 07:21 PM
JOHNNY CASH's Avatar
Guys here's an important tip if you're new to using a buffer. Never start off trying to do a big area on the visible part of your car. If at all possible get some scrap metal to practice on and if that's not available start off on your car in a small spot that's kinda out of the way.
Otherwise you might have to deal with the OP's issue.
Got it!
Old Mar 30, 2011 | 09:38 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
Originally Posted by takeNotes
LOL what? Waxing by hand easily takes longer. Using a buffer, buffs the wax into the clear coat as opposed to just applying it when you do it by hand. Unless, that is, you apply constant moderate pressure by hand, which would probably kill your arm after doing a quarter panel and a door Ive been doing it by hand lately, since i havent had time to get a new buffer. Its a PITA for sure but well worth it
Originally Posted by 4D05G35
A foam pad on a buffer will save you a ton of time applying the wax.
Hand wax jobs are good for a few washes, use a buffer if you are serious about it. You can polish a turd, but it will only glow for so long. Put some work into it and it will shine for a long while.
Waxing by hand and with a machine provide the same EXACT results if you're applying the right way (as THIN as possible!)
Yes using a buffer is faster but not always the best method. Take paste wax for instance, you can only apply paste wax by hand.
To the OP, I have never waxed a car with snow on the ground and have never seen anything like the problem your pictures depicts. It could very well be that the wax hardened up because it was so cold outside.
One great tip for using a buffer, ALWAYS start the machine off at the LOWEST speed and work your way up from there. Depending on the buffer you should be on the lowest or close to when applying wax/sealant. If you have one of those $29.99 generic buffers from autozone, it's as good as garbage.
Old Mar 30, 2011 | 10:02 PM
RogerG35's Avatar
Same thing happened to my friend's SI. He used an old cloth and once we switched to a new one, the problem didn't happen.
Old Mar 31, 2011 | 06:17 PM
strykez's Avatar
hey everyone, have an update. I got a friend that works at a body shop he looked at it and said i'd have to get it out with wetsanding but some parts are through the clear coat.. he said my headlight should be fine and could be wetsanded out. Anyways i'll be painting the hood fender and bumper.. going to try and work out a deal with the body shop since i work at an auto shop and we deal with eachother all the time. Maybe can do some mechanical work for them in exchange for the paint job. Also he said there must of been compound on the buffer that was hardened and just dug into my paint.. i have splatter on my windshield hopefully i can get it off with a razor blade thanks to everyone who replied and helped me out.. was pretty stressed and although the worst thing came out of it which is paint at least i know what i have to do now and can get it fixed
Old Mar 31, 2011 | 06:25 PM
Houston5.0Jay's Avatar
Wow.. my "friend" would be the one paying for my paint thats for sure..
You shouldn't be responsible for damage he caused to your car through stupidity. he said he was qualified to do it.. hold him responsible.
Old May 5, 2011 | 10:09 PM
Firligic's Avatar
can his incident happen to if you do this by hand with foam pads and microfiber to wipe off the wax?
cuz i would kill myself if this happened to me
Old May 5, 2011 | 10:22 PM
  #30
joedaddy1's Avatar
i doubt it.. unless you got some crazy dirt/rock/boulder on your pads/mf
