Help! I just bought a used G and it gets 9 MPG!
Old Apr 11, 2011 | 04:29 PM
bboynicku's Avatar
i would also reset the ecu using the pedal method. You can search for how to do it on here.
Old Apr 11, 2011 | 07:20 PM
Enigmatic42's Avatar
Originally Posted by vinco
Clean your MAFS. Depending on mileage, it could be your cam and/or crankshaft position sensor. Change spark plugs.
What is a MAFS? Mileage is 74,000
I'll def try plugs first I think
Old Apr 11, 2011 | 07:23 PM
Originally Posted by luvmyzx6r
You filled up after 80 miles? that's probably the reason why you're getting 9 mpg.
Try driving about 200 miles than recalculating it.
Trust me I've driven 2000 miles and checked many times, it's bad mileage.
Old Apr 11, 2011 | 07:25 PM
Originally Posted by anynigma
That totally sucks. I sympathize, this must be so frustrating. I will try to help make it as painless as possible, but no guarantees...
Anynigma's easy 6 step method to restoring fuel economy.
1) Check Air Filter, if dirty, replace
2) Check Spark Plugs, if dirty or large gap, replace
3) Reset ECU
4) Reset Idle Throttle Body Position and Accelerator Pedal Position.
5) Clean Throttle Body
6) Take it to a trusted shop and say wtf
DIY's or posts with useful info can be found via search.
Thanks for your detailed reply I'll definitely check out those ideas.
Old Apr 11, 2011 | 07:28 PM
walshtj's Avatar
^ MAFS is the mass air flow sensor located in your inpipe to your throttle body.. Its a little black senor, I think on the right.. You can look up diagrams if you need to.
Old Feb 24, 2023 | 12:37 AM
CheemaInfiniti's Avatar
infiniti g35x
I got the same problem, it also does 9 mpg but, drives fine, air filter clean, clean maf sensor. It does have a p0024 engine light could that maybe contribute to the problem. The engine light doesn't limit the car in any way though.
Old Feb 24, 2023 | 02:26 AM
12pawsinn's Avatar
Relatively stock
Do you get winter fuel over there ?? It's fuel that the snow regions use to help fuel mot freeze. If so, that will be a good idea for bad fuel consumption, also you letting the car idle to warm up ??
check the o2 sensors
Old Feb 25, 2023 | 02:42 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Guessing you have a V36 chassis since your description says you have AWD and the V35 chassis didn't have exhaust timing on the AWD models.
An HR engine getting only 9mpg is definitely a problem unless you have a really heavy foot. How many tanks of gas have you measured to calculate your MPG, and you're doing ACTUAL MATH right not just going off the onboard MPG display?
Old Feb 26, 2023 | 01:54 AM
infiniti g35x
I haven't checked doing the actual math but it sure does feel like 9 mpg since my fuel gauge drops so quickly, so far I have tried to clean maf sensor, and new air filters but nothing seemed to work. It also runs perfectly, so I am confused about why the mileage is so bad. It does have a p0024 engine code though, could that maybe contribute?
Old Feb 26, 2023 | 10:10 AM
cleric670's Avatar
BANNED!!!
Gotta track actual mileage, you can't just "guess it's getting 9mpg". Fill up the tank, reset the trip odometer, drive until it's about 1/2 full, fill up again, check how many gallons it took and divide the trip odometer miles by the gallons consumed.
Usually the G35 gets like 13-15mpg city, 20-23 highway.
That code is for the exhaust cam magnet retarder, it shouldn't have that much of an impact on mpg.
Old Apr 28, 2023 | 08:26 PM
InfinitiCheema's Avatar
infiniti g35x
I did the calculation and got 8 mpg one lower than the onboard display. I'm confused because my car runs perfectly.
Old Apr 29, 2023 | 12:46 PM
cleric670's Avatar
BANNED!!!
I'd start with fresh plugs and air filters
Old May 29, 2023 | 05:57 AM
Tc2022's Avatar
Coupe
Hey, I have a 2004 g35 coupe and also a 2006 coupe, I'm having the same problem with both cars,
my 06 I'm getting about 220km to a full tank that's 130 miles ​​​
my 04 isn't to much better I'm getting about 390km on a full tank. The exhaust pipe is Black and if I stomp on the gas since I have a small exhaust leak my entire car fills with smoke.
Oil is another huge issue, on average im putting a litter of oil per 300km . I've been to a point of having less then a 1/4 coffee cup of oil left in the car and no oil light came on.
I did some searching on line and found some very interesting things about this car. Infiniti recalled a select run of cars baised on the v.i.n regarding oil consumption issues . Which is strange because this is were the fuel problem kicks in, if your car is using a high amount of oil your gas use will increase, which will destroy your engine. Unburnt gas will eat your seals and valves and start leaking into your oil. Then after time you start hearing rattling once hitting about 3000 rpm that's when your engine is on the way out. The interesting part of this story is Infiniti knows of the issue, and simply said oh well and made a small recall to make it look good. But when in fact every v6 3.5 engine from 2004-2006 shouldve been recalled.
how many g35 or and 3.5 from 2004-2006 do you see on the road in good running (engine) shape over 300,000km. . Most I've seen at 250,000-300,000 are in the junk yard
Old May 29, 2023 | 09:59 AM
cleric670's Avatar
BANNED!!!
These engines run fine drinking oil, the reason they're in the scrap yard is the owner didn't check the oil and ran out Most seem to die from natural causes at around 200k-250k miles which seems normal. Yours however does appear to be having problems, it should not smell like exhaust inside your car, nor should it be blowing smoke out of the tailpipe.
The Infiniti oil consumption recall only applied to the rev-up engine iirc.
My gas mileage is dependent entirely on my right foot, I can get it down into single digit mileage but if I'm TRYING to get good mileage I can manage about 15mpg city and 20 highway.
SePa_8310
Sep 16, 2015 04:32 AM
Terry_G35
Sep 10, 2015 08:17 PM
Danielek
Sep 10, 2015 06:18 PM
Batfinity
Intake & Exhaust
Sep 9, 2015 09:21 AM
