Valvoline Oil Sucks
Old Apr 21, 2011 | 10:45 AM
PAIXAO's Avatar
Bob Is The Oil Guy...
http://www.bobistheoilguy.com/
Old Apr 21, 2011 | 02:22 PM
IVANISINLA's Avatar
Thanx I checked it out I guess mobile is the one and it even tells you the oil filter farm model I think
Old Apr 30, 2011 | 06:52 PM
slim17265's Avatar
Originally Posted by luvmyzx6r
Sike, it probably doesn't suck but my VQ sure doesn't like it.
I've always used mobile 1 full or Castro EDGE Syntec full. Well, last oil change, I used Valvoline Synpower full synthetic 5w30 since it was on sale. 30 bucks for 5 quarts and pure one "high performance" oil filter. After a thousand miles I checked my dipstick and it was below the low mark. I was freaking out because I never burned this much oil before. Usually only a half to 1 quart every 4000 miles or less. So I drained the oil on a clean bucket and it turns out, I burned almost 2 quarts. I was freaking out! And it was dark already. So I put the oil back in and added two quarts of 5w 30 Mobile 1 full sythetic and after 1200 miles I drained the oil for an early oil change and this time I burned through a little over half a quart of oil after adding mobile 1
I am using Castro EDGE Syntec 10w 40 right now and so far so good and registering well on the dipstick. Definitely don't think it was my engine but the oil I was using.
So yeah, any of you guys ever try Valvoline before? I'm also using K & N Oil filter right now. It was 14 bucks. Every try that too? Definitely watching the types of oil I use now.
2003 Infiniti G35 6mt with over 100k on it.
it is NOT the OIL or the filter. if oil is black you are getting oil past the top compression ring and BURNING it...this maybe because the oil ring is not scraping all of the oil off of the bore. Try one quart Rislone for 100 miles, then drain and refill with 20x40 non detergent any brand
Old Apr 30, 2011 | 07:20 PM
thescreensavers's Avatar
Mr.202?
^ oil natural gets dark with use as it hold stuff into the oil. I bet thats what is happening
Also K&N is very good same as M1 filter.
Its Castrol btw, with an L
Originally Posted by Hotdawwgman
I am a firm believer of an OEM Oil filter, and I religiously use Motul 8100 10W30. I notice a big differnece at my oil change intervals. As far as I know, the VQ motors are very sensitive to oils. I have had great usuage out of the Motul
The OEM filter sucks, if you like cardboard end caps fragile filter media, and a antidrain back valve that hardly works go ahead.
Have you ever done a UOA? If not then you know jack of how your oil is working.
I rather just buy a Pureone if I had to pay or get a K&N/M1, Bosch D+ when they are on sale
f22raptor
Mar 18, 2016 08:50 AM
prinny
Nov 22, 2015 11:07 PM
mbe32
Nov 13, 2015 11:09 PM
9tray turbo
Sep 29, 2015 10:22 PM
