Noobish question
Old Apr 21, 2011 | 04:12 PM
b-weezy's Avatar
Noobish question
Before I spend my hard earned cash on parts I want, I need to know of they all fit together because I can't remember if there was a thread about these parts not fitting together. Will the kinetix ssv manifold, MREV2 and motordyne spacer fit together under a stock 06 hood?
Old Apr 21, 2011 | 10:15 PM
heythatsneat's Avatar
to my knowledge, it does not.
it replaces both upper and lower plenums.
if im wrong someone hopefully will correct me.
stock hood will definitely fit though.
Old Apr 22, 2011 | 06:11 PM
b-weezy's Avatar
so no mrev then but what about the 5/16 spacer?
Old Apr 22, 2011 | 06:16 PM
Blue Dream's Avatar
I drove ttrank's car solo
You are absolutely correct. The SSV won't produce much in the way of gains but it sure does look good. OP if you want power gains, stick to the MREV2 and the spacer. They produce good results on the rev up and even more if you get the car tuned.
Old Apr 22, 2011 | 06:20 PM
^thanks!
as for the mrev and spacer, i have this setup and it was quite noticeable on the revup. you should be very pleased with this upgrade.
Old Apr 22, 2011 | 06:23 PM
the spacer uses the stock upper plenum and lower collector or mrev. the mrev is just a direct replacement of the lower collector.
Old Apr 22, 2011 | 10:23 PM
b-weezy's Avatar
Oh ok. It seems that everyone has a different opinion on the ssv though. Some say it gives you good gains, other say they lose power due to heat soaking issues and it's just a shiny waste of time under your hood. Would a company really produce a product without r&d to see if this is really an issue? Anybody know anyone with the ssv and if so was it worth it or I shouldnt even waste my time.
Old Apr 23, 2011 | 04:22 AM
may i ask why you are so hooked on the ssv?
Old Apr 23, 2011 | 04:48 AM
Blue Dream's Avatar
The SSV has been shown to produce decent gains on a FI application, normally aspirated motors not so much. My guess is he's hooked because of the look.
I considered one for a while but the price vs. gains weren't worth it to me.
Old Apr 23, 2011 | 05:04 AM
b-weezy's Avatar
Yeah truth be told it's shiny so I thought it might do me some good but if it's not needed then I will just do the MREV and spacer.
Old Apr 23, 2011 | 09:40 AM
gary c's Avatar
Yeah truth be told it's shiny so I thought it might do me some good but if it's not needed then I will just do the MREV2 and SPACER.
Since you have a '06 with a MT this....^....is the best mod you can make, good choice! With this mod and HFCs you will have picked up close to 30 HP, not bad for the cost....
Gary
Old Apr 23, 2011 | 10:12 AM
imo for the looks id go with the cosworth plenum. it looks soo much meaner than the ssv. maybe because it looks more balanced and i have craaazy OCD haha
Old Apr 23, 2011 | 11:59 AM
gary c's Avatar
........Sure the Cosworth is pretty but you need to measure cost against return, is it that much better than MotorDynes spacer/mrev2 combination? I would only go that direction if I was going Vortech FI.
Gary
Old Apr 23, 2011 | 12:52 PM
^agreed. which is why i went with the spacer/mrev2 combo. lol
im just stating that in my opinion, the cosworth looks prettier than the SSV.
Old Apr 23, 2011 | 09:56 PM
b-weezy's Avatar
Does the cosworth manifold make hp without beak soak issues? I'm hoping for that price it does
