Tein H techs Questions
Old Apr 29, 2011 | 01:11 AM
acid0601's Avatar
Hello guys try to search but could not find a direct answer. If you have Oem Struts and Get H tech springs ? how is the camber can it still be align withought camber kit?? thanks guy , my first G35 and trying to start some mods 05 G35 coupe.
Old Apr 29, 2011 | 01:20 AM
Xet's Avatar
Xet
H-techs normally don't need any aftermarket camber kits in order to get back into spec. Once in a while someone for whatever reason may not be able to get back totally in spec, but that is quite rare and it isn't a big deal running with a bit more camber than stock spec.
Old Apr 29, 2011 | 01:27 AM
acid0601's Avatar
Thanks for really fast reply and clarifying that up for me looks like I'll be getting these this weekend after all thanks again I'll make sure I'll post pics once installed
Cheers
Old Apr 29, 2011 | 01:36 AM
fstasfk_G's Avatar
Yea cuz the htechs lower less than an 1" so u shud be fine
Old Apr 29, 2011 | 03:02 PM
gary c's Avatar
All of the above posts....^.... are incorrect! (Wrong) After you install the springs have your G aligned and see what the alignment tech has to say about your tire wear. Our G35s have very little adjust ability in our suspensions, often stock heights will cause the inside of your tires to wear prematurely due to worn/weak springs. If you lower your G any amount you'll need both front and rear camber adjusters unless your Daddy owns a tire company! Had you done a SEARCH this has been discussed and answered a gazillion times....
Gary
Old Apr 29, 2011 | 03:05 PM
spinna001's Avatar
Gary
Gary is the man
Old Apr 29, 2011 | 04:02 PM
acid0601's Avatar
I search and people say you don't need a camber and others say you do . That's y I was asking in this thread. But I guess I'll have to get them and find out myself thanks everyone for the input.
Old Apr 29, 2011 | 04:09 PM
gary c's Avatar
All you need do is ask the mechanic doing your alignment how far off OE specs your suspension is. A person doing his job right should offer you that information anyway, I always did!
Gary
Old Apr 29, 2011 | 04:32 PM
4D05G35's Avatar
Focus on your TOE specs.
Camber will wear the inner side of your tires more, but TOE will eat up tires.
As Gary pointed out our cars already eat up tires in stock form, but another .5 degrees of camber wont chew up your tires much faster as long as your TOE is in spec.
Old Apr 29, 2011 | 04:46 PM
g35sweetness's Avatar
i got oem 350z struts coilovers and sprints, full set up fs, best offer
Old Apr 29, 2011 | 07:01 PM
acid0601's Avatar
Thanks do the heads up . What can u do to prevent the toe to get worse ? Will it be worse once I install the springs on ( h techs ) ? Thanks again for the help
Old May 1, 2011 | 12:57 AM
acid0601's Avatar
Taking car for Alignment on Monday ill let you guys know how it went. thanks guys again
Old May 1, 2011 | 01:07 AM
MADtotheA's Avatar
Which h techs are you going with? Interested to see your results..
Old May 1, 2011 | 01:22 AM
acid0601's Avatar
I just installed today H techs Tein , bought them form a form member here .
Old May 1, 2011 | 01:51 AM
MADtotheA's Avatar
Maybe I should have clarified; which h techs did you buy? Z or G h techs? And how was your camber/toe after you took it to the alignment shop?
