Spacer question
Old May 8, 2011 | 09:17 AM
messinax's Avatar
Spacer question
Hi everyone,
Just wondering IF I'll need spacers and if so, what sizes do you guys recommend.
My set-up:
19x9.5 24mm R disk 245/35/19
19x10.5 +23mm O disk 275/35/19
Dropped currently on SWIFT springs (Drop: 1.0" Front, 0.6" Rear)
I also did the "Springmount Mod" so the back is actually dropped another 0.5" I'm guessing.
I was originally going to get 15mm for the fronts, and 20mm for the back.
Any help/insight would be much appreciated. Thanks!
Dave
Old May 8, 2011 | 01:14 PM
walshtj's Avatar
Not too sure about wheels, but those offsets look pretty good to me. Id say those would be fine, although may need to bump it up to 20mm front and 25mm back.
Old May 8, 2011 | 01:29 PM
oneup's Avatar
I had meisters in the same spec as you did and with those size tires you can push it by running a 20mm in the rear if youre fenders are rolled but youre safe with 15mm in the front
jsimonk
Dec 22, 2023 03:49 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Soumilg
Jul 18, 2015 12:33 PM
