HELP PLEASE! car wont crank
Old May 13, 2011 | 02:59 PM
carbonspeed's Avatar
I drove my car to the gas station. Got home. An hour later I tried to start it. But it didn't start. The car didn't even crank. I know the battery is fine though. If anyone can help. Thanks alot!
Old May 13, 2011 | 03:06 PM
dEnbOy.GFM's Avatar
Does the car have power? (lights, radio, etc work)
Edit: also, is your car at or mt?
Old May 13, 2011 | 04:04 PM
yes, all of the electronics are working fine. It is a 6 speed manual transmission. However, when I turn my key, it's nothing happens. my stereo turns on. My horn works fine. I'm thinking it's either the ignition coil or the ignition control module?
Old May 13, 2011 | 04:23 PM
saywat?'s Avatar
manually press the clutch switch and try to turn the car on
Old May 13, 2011 | 04:35 PM
so where is the clutch switch located? its not the clutch pedal, correct?
Old May 13, 2011 | 04:38 PM
saywat?'s Avatar
^look underneath where the clutch pedal is ull see a black or red switch that the clutch pedal rubber stopper presses when its fully depressed.
dEnbOy.GFM's Avatar
It could be the starter switch under the clutch. That's a more common problem. If not that, it could just be the starter and solenoid. Those are the other more common issues. If those are fine, then it could be the coils. When you turn the key, do you hear a loud click?
Old May 13, 2011 | 04:46 PM
hmm...well, there is no loud click when i turn the key
Old May 13, 2011 | 06:51 PM
strykez's Avatar
try and bump start it since u have a manual tranny. First thing you should do is try boosting it although since your accessories are on its probably not the battery. Check the clutch switch everyones talking about if it's not that try and look up fuses for the starter. If thats good check the power at the starter signal wire, if that has power when you try and crank over then you need a starter.
Old May 13, 2011 | 07:25 PM
saywat?'s Avatar
^if by bump start it u mean push the car and turn it on i recall in the manual it said not to do that
Old May 14, 2011 | 10:07 AM
i tried manually pressing the clutch button you guys said. Still nothing. Is there any other way you guys can help me? thanks alot.
Old May 14, 2011 | 12:00 PM
dEnbOy.GFM's Avatar
It might be either the starter motor or solenoid..
The click means there is current through the coils but there isn't power to the main contacts that power the starter motor. Hard to say tho, because it could also be a bad starter motor..
The only way to know for sure is to measure the voltages.. You can test the solenoid terminal where it connects to the motor. If there is no reading when you turn the key, that probably mean the solenoid is bad and you gotta replace that.. If the voltage is normal, then it might be the starter motor and you can replace that.
Old May 14, 2011 | 12:31 PM
faiz23's Avatar
I had an issue with my acura starter and it did a very similar thing. I heard at one point while diagnosing the starter than you can either Hit the starter with a stick and see if it fires up the car kinda like when people hit the window motor to get it to work again temporarily. Also I have heard of people running a power wire direct to starter or solenoid to trigger it manually and rule out a bad cable.
http://www.myvwlemon.com/ubb/Forum1/HTML/002926.html
DIY: troubleshooting
http://forums.vwvortex.com/showthread.php?2359900
Old May 14, 2011 | 12:50 PM
strykez's Avatar
ya you can try jumping the starter to see if it'll engage, you can also try hitting it that works sometimes to.
Old May 14, 2011 | 12:55 PM
dofu's Avatar
20 Year Member
It's becoming common to see this in G35s now... change your starter. If it ever cranks but won't start, start checking your sensors, more specifically the crank sensor. And I'm saying this assuming you've already tried jumping the car to make sure it's not the battery of course.
