Blue Dream
I drove ttrank's car solo
close
- Join DateMar 2009
- LocationBy the sea, Tx
iTrader Positive Feedback100
iTrader Feedback Score(50)
- My RideG35 sedan w/ too much money in mods
Liked:1,488 Times in 1,223 Posts
Quote:
lol springs and slammed aren't words that go together.
L.........M..........A........OOriginally Posted by Xet
It will settle, but that seems weird. Can you take a picture of how the springs are installed??lol springs and slammed aren't words that go together.
Some people just don't seem to get it.
gary c
close
- Join DateFeb 2005
- LocationValencia, Ca
iTrader Feedback Score(10)
Liked:1,133 Times in 1,003 Posts
They'll probably settle after you drive it a few miles. Does H&R offer any information about how much lower your G35 will sit with their springs installed? Tein does and they're pretty accurate.
The terminology slammed doesn't apply to springs but does it apply to drivable? If SLICK was on coilovers and any lower I couldn't get up my driveway and into my garage. Those are major considerations when lowering your ride....
Gary
Gary
Front 1.1" drop/ Rear 1" drop.
The body shop said they even called H&R and checked the part numbers and everything matches what it should be but H&R told them they have been having problems with too much drop instead of not enough. So idk wtf is going on lol. Its a guy from Lingenfelter that is installing them so I dont imagine he is doin it wrong.
Quote:
After H&R Sport Springs
WTF! Thats AFTER the install?? Something is definitely wrong there.Originally Posted by G35INTHE260
So the Body shop that is installing my After H&R Sport Springs
See if you can get some pics of the install.
Blue Dream
close
- Join DateMar 2009
First of all in that pic^^ it doesn't look like the back end is sitting completely on the ground, the tire doesn't seem compressed enough.
Second make sure the shop seated the rubber piece/spring properly in the bottom of the spring bucket and the same for the spring mount up top on the rear wheels. If the springs aren't lined up properly with the grooves it could cause the car to sit too high, and would be dangerous for driving.
Exactly, that's why I asked the OP for pics of the install but it doesn't seem like he cares to get them.... w/e I guess, not my car/life.Originally Posted by Blue Dream
First of all in that pic^^ it doesn't look like the back end is sitting completely on the ground, the tire doesn't seem compressed enough.Second make sure the shop seated the rubber piece/spring properly in the bottom of the spring bucket and the same for the spring mount up top on the rear wheels. If the springs aren't lined up properly with the grooves it could cause the car to sit too high, and would be dangerous for driving.
Its the weekend lol the shop is closed. Believe me I am chomping at the bit to try and get in there and take pics and overlook things.
I noticed the same thing that it looked like the car wasnt sitting flat like there is a jack behind where u cant see or something. I swear thats what it looks like.
ahh ic, wait why do they still have your car?Originally Posted by G35INTHE260
Its the weekend lol the shop is closed. Believe me I am chomping at the bit to try and get in there and take pics and overlook things. I noticed the same thing that it looked like the car wasnt sitting flat like there is a jack behind where u cant see or something. I swear thats what it looks like.
Had to order new sleeves for the front control arms. Damaged the stock ones when they pulled them off the old ones
Raised the car after putting lowering springs on... damaged control arms during uninstall... Id go elsewhere... sounds like they dont have a clue as to what theyre doing
Ive installed my fair share of coilovers, springs, shocks, and struts and it should take about 2 hours TOPS if you know what youre doing, not 2+ days
And anyone who's done suspension, or even just jacked up a car, knows that unless you move the car after putting it back on the ground, its gonna sit higher.
It was just those little rubber pieces that u have to switch over to the spc's. It was 11bucks so no biggy. And they have had my car awhile cuz I got rear ended and they are fixing it as well. And installing my other body pieces. Should get it back today tho. Will post pics after I drive it awhile and hopefully it settles
saywat?
close
- Join DateApr 2009
iTrader Feedback Score(5)
Liked:484 Times in 430 Posts
my car needed no settling after installing new springs. and def didnt look or get raised after either
Ok so the moral of this story is to not jump to conclusions. The car settled after a few test drives while aligning it. So if any other noob runs into this hopefully this thread will help.
