Engine feels like it misses when accelerating hard.
Old May 25, 2011 | 11:28 PM
jsmith29's Avatar
Hey guys.
Having a problem with my 04 g35c, 6mt. When I accelerate hard, at about 3500 rpms it feels like the engine misses and the entire car jolts. In other words, all power is lost for .5 a sec. If I slowly build up to those RPMS this does not happen.
Any ideas on what could be causing this?
I'm at 95k miles, and I first noticed this yesterday. It was not doing this before this last weekend.
I'm about to take the car on a fairly long drive, and I'd like to get the issue resolved before I do.
Any direction would be appreciated!
Old May 26, 2011 | 12:07 AM
rdeverett's Avatar
Sounds like your clutch may be slipping. I'm no expert though.
Old May 26, 2011 | 05:15 AM
gveng's Avatar
if the clutch is going out the car won't jolt, it will rev up and then catch.
Old May 26, 2011 | 10:00 AM
Ellis's Avatar
Are you noticing the problem every time you accelerate? Or does to car seem to only do it once up to temp?
Old May 26, 2011 | 10:21 AM
jsmith29's Avatar
Seems to do it only when I'm giving it a little more gas. Like I said, if I accelerate slowly it doesn't happen.
The clutch doesn't feel like it has a hard time catching, but I could be wrong.
Old May 26, 2011 | 09:47 PM
jsmith29's Avatar
Pretty sure I figured it out.
Tonight on the way home I took it into higher RPMs and the engine stuttered. VDC, Slip, SES light came on. Same sypmtoms as 4 months ago when I had to replace the bank 1 Camshaft position sensor. My guess is bank 2 has gone bad, as many people here as well as my mechanic said they usually go bad around the same time.
Here's hopin - 80 dollars and 2 hours of my day off (quality time with my car) sounds a helluva lot better then a new clutch or worse. The clutch feels great, no slippage at all going into first/reverse and shifts are smooth as ever.
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
joedaddy1
Jul 28, 2015 02:58 PM
mjfenix
Jul 17, 2015 02:07 PM
