window sound after replacing the motor
Old May 27, 2011 | 10:28 AM
avinashchanagal's Avatar
So i replaced my driver side window motor on my 03 coupe........ and now every time i close the door with the glass half rolled ud....... i hear a thud sound, it sounds like the glass beats against something........ it doesn't make any sound while i go over the bumps though. Also i made sure i tightened each and every thing while putting back
Any one had the same problem........ how do i fix it, it's irritating.
I tried the search but it didn't help, may be i'm using the wrong key words
Thanks
Old May 27, 2011 | 12:44 PM
Affalterbach's Avatar
Well, when my right side window is rolled down more than 1/4" of the way, it will make a rattling sound like metal on metal when going over bumps and cracks in the road, especially the little round ceramic ***** on the freeway that separate the lanes.
Old May 27, 2011 | 03:58 PM
AustinG35's Avatar
Did you remember to perform the window motor reset feature to properly reset the top and bottom stops?
Old May 27, 2011 | 09:35 PM
saywat?'s Avatar
^i think hes refering to the glass making that horrible shaking sound like its gonna fall apart when he closes his door. OP, tightening the 2 big screws on the bottom of the panel with the washers where the rail bolts to helps
Old May 27, 2011 | 10:30 PM
WACK BEATS's Avatar
Yup. Tighten everything down! ha!
Old May 28, 2011 | 10:29 AM
I didn't have to reset it as it was doing the up nd dwn and automatic features as defined by default.
Old May 28, 2011 | 10:30 AM
Thanks i'll try that.
Hasanbaloch
Feb 29, 2024 08:45 PM
will091195
Jul 27, 2015 09:19 PM
Kal Hamm
Jul 24, 2015 08:55 AM
apintojr
Jul 23, 2015 10:52 AM
vstypicals
Jul 20, 2015 10:55 PM
