engine tear down and rebuild
Old Jun 15, 2011 | 01:29 PM
vp-g's Avatar
Originally Posted by smitty89
No I didn't I was coming home from the track and slipped my mind to check my oil
i still dont understand how you ran out of oil
Old Jun 15, 2011 | 02:04 PM
smitty89's Avatar
It was burning oil and I found out it had a leak coming from the oil filter housing and the fact that I ran it 18 times at the track prob burned the last of it
Old Jun 15, 2011 | 02:20 PM
gwood5turbo's Avatar
unfortunately I blew mine as well.. fixin to get started on rebuilding it! Keep us posted!
Old Jun 21, 2011 | 11:41 PM
smitty89's Avatar
Almost finished putting cams and timming chain back in
Old Jun 21, 2011 | 11:51 PM
the_sedan's Avatar
i hope you replaced the piston rings as well as that is the actual problem with these motors. and you said the oil cooler seal was leaking, im guessing you replaced that too? otherwise, seems like a budget rebuild. hope all works out well. i just finished my build!
Old Jun 22, 2011 | 03:02 AM
smitty89's Avatar
This is a diff motor I put a hole through the block on the original this is a running motor with 90k on it I ported heads replaced valve seals and put hearders on it ported lower and mid intake manifold put thinner head gaskets on.
Old Jun 26, 2011 | 12:17 AM
smitty89's Avatar
Got just about all of it pulled out today just need the ac condenser off and engine mounts took us only 4 hours
Old Jun 26, 2011 | 04:10 AM
Defratos's Avatar
You're Despicable
looking good, just out of curiosity what is the car jacked up on? it's up soo high
Old Jun 26, 2011 | 04:36 AM
faiz23's Avatar
looks like a cinder block
Old Jun 26, 2011 | 04:49 AM
smitty89's Avatar
Sure is I have to use what I got on hand
Old Jun 26, 2011 | 05:21 AM
Defratos's Avatar
You're Despicable
lol I saw the bricks poking out from the bottom but didn't think you were using them haha
KSWAY's Avatar
Dude get some jack stands. Only time cinder blocks should be used is when you're jacking the wheels. But seriously man, that scares me to see those blocks under the car and you guys crawling under it also.
Old Jun 26, 2011 | 03:31 PM
Majiks's Avatar
sub'd
Old Jun 26, 2011 | 03:47 PM
HwyDrftr's Avatar
Cinder blocks are sketchy, at least keep the jack under there or keep a wheel and tire under there with you to keep a little space to breathe if one of those blocks cracks.
Old Jun 26, 2011 | 03:48 PM
  #30
smitty89's Avatar
We are short on supplies so that's all I got but I'm sure they will hold ill post more pics today ill have the old motor and trans all the way out
