Overheating problem..
Old Jun 6, 2011 | 05:10 PM
an701's Avatar
Hello everyone, I haven't posted on here for a while. Having an overheating issue. This happens only when it gets extremely hot here in South West Florida. One of the fans never turns on. Do you guys know what could be the problem? I am pretty sure there is no air in the system and at first when it was overheating I noticed that the second fan doesn't turn so I replaced the whole cooling fan assembly and still having the same problem. Is there a relay or fuse that I could check? Any suggestions? BTW its an 05 coupe automatic
Old Jun 6, 2011 | 05:38 PM
thescreensavers's Avatar
Mr.202?
Google "35 Coupe Service Manual" it should help
MJ-G35's Avatar
Having the same problem, I know my left fan isn't working. I haven't replaced mine yet, does it happen when your sitting still, or while your driving?
Old Jun 6, 2011 | 05:56 PM
an701's Avatar
It usually happens during heavy traffic, while idling and driving..
Glad to know that I am not the only one. I can't believe we have no solution to this problem
Old Jun 6, 2011 | 06:41 PM
MJ-G35's Avatar
mine only happens when it's really hot, and the ac is on, but never while driving.
Old Jun 6, 2011 | 06:50 PM
rimshaker's Avatar
Theres a warranty extention for the radiator fan motors. Applies to 04-07 coupes. Extends original warranty to 96 months/100k miles.
When you replaced the cooling assembly, did that include both fan motors (the round metal ones). Over time some have been found to develop too much electrical resistance and causing malfunctions. Happened to my 07 coupe last year. Both motors had to be replaced. Totally free of charge at dealership (wouldve been $500 parts/labor for both motors).
Old Jun 6, 2011 | 06:59 PM
an701's Avatar
Yes, I replaced motors + shroud.
I would assume it would overheat more during idling. I am pretty its the not the fans. I think its an electrical (Relay) related issue.
Old Jun 6, 2011 | 08:34 PM
MJ-G35's Avatar
Where did you get this info?
Old Jun 6, 2011 | 10:06 PM
rimshaker's Avatar
^^ Received a warranty notification letter early last year. There's no TSB about it, but any dealer can verify it.
Old Jun 7, 2011 | 01:03 PM
MJ-G35's Avatar
Ok, thanks.
Old Jun 7, 2011 | 01:16 PM
BW350GTskyline's Avatar
there is actually a recall on the 04 fan shroud motor giving out.. i received a letter from infiniti corp stating that issue. but when i went to the dealer and showed them the letter and asked if they would replace these parts they said they couldnt because it has not failed yet. so before they charge you for something that should be replaced under the warranty
Old Jun 7, 2011 | 02:11 PM
MJ-G35's Avatar
I have an 05, and my left fan has stopped working.
Old Jun 7, 2011 | 06:40 PM
an701's Avatar
^ wow I had no idea that this was so common...
come on peoplez lets figure this out
Old Jun 8, 2011 | 05:10 PM
MJ-G35's Avatar
Just got off the phone with the dealership, taking my G in the morning to get fixed. They told me the fans are covered. Wish me luck on the fix!
Old Jun 8, 2011 | 05:12 PM
MJ-G35's Avatar
Thanks Bro, you saved me some loot!!
