Electrical problem!! doesnt look like its the fuse!
Old Jun 13, 2011 | 10:13 PM
Theanimedude's Avatar
Hello!
So recently when i start up my car, the gauge lights, radio and AC doesnt work.
When i first turn on the car, its fine. After starting the engine, it all goes to hell. Even the mirrors doesnt move. i checked all the fuses under the driver side wheel near the clutch pedal and all fuses seem to be fine. i replaced teh heated mirror and mirror fuses, still no luck.
Is this that issue where i have to replace the whole radio or something like that??? i saw some people that had the same issue but...... no solution... besides the dealer and paying 750 bucks...
Old Jun 13, 2011 | 11:16 PM
03XG35's Avatar
I solved this same problem on my '03 coupe last week.
The radio wouldn't work, neither would any of the buttons & the AC would be on constantly.. the only way to turn it off was to have the car off. All I did was disconnect the battery for an hour and still to this day (a week later) it all works perfect.
Old Jun 14, 2011 | 12:15 AM
LEDmarkers's Avatar
Did you try the hidden fuse panel behind the battery on the passenger side .You have to completely remove the battery to get to them . The tail fuse there causes those exact things not to work . Maybe its just loose ?
Old Jun 14, 2011 | 08:57 AM
not yet, whats a tail fuse? the fuses for the tailights??
I'll check it out today when i get home. Can't wait to get this fixed. i was actually in the middle of selling my car. changed all the fluids, then this had to happen, its a sign, i should keep her. haha
Old Jun 14, 2011 | 09:39 AM
LEDmarkers's Avatar
Yes it the tail light fuse however lots of interior things work on that fuse as well like radio/ac buttons , door lights etc .
Old Jun 15, 2011 | 09:51 PM
Okay,
So i took off the battery cover and saw the fuse box. it seems to all work.
BUT!!!! i did figure something out...
It all goes to hell onces i turn the engine. So i started tapping the area around the key while the engine is on, and it all came back!!!
happens every time i tap around it.... so its the ignition switch??? Do i have to replace that????
Old Jun 15, 2011 | 11:12 PM
LEDmarkers's Avatar
Thats a strange problem . Not sure if its the ignition switch . If the car turns on fine i would guess not but not sure . Btw the fuse box is not the one under the battery cover . You have to remove the battery completly and also remove the window trim to access it . It is mounted to the firewall inside a black cylindrical cover .
Old Jun 15, 2011 | 11:22 PM
okay so basically its behind the battery correct? i'll have to remove the batter and anything other plastic piece behind it. and its a black cover. Is there a picture of it anywhere?
Old Jun 20, 2011 | 10:52 PM
Thumbs up
Okay, so which one is the tail fuse?
theres no diagram...
Attached Thumbnails Electrical problem!! doesnt look like its the fuse!-imag0157.jpg   Electrical problem!! doesnt look like its the fuse!-imag0158.jpg
Freeman186
Sep 6, 2023 10:07 AM
Danielek
May 1, 2022 01:28 PM
esotericrider
V36 General Tech Questions
Mar 4, 2019 07:53 PM
magnetism80
Feb 1, 2019 10:00 AM
