Navigation problem---Help plz!!
Old Oct 18, 2011 | 10:56 AM
  #46
GHETTOGRAMMA's Avatar
03 sedan 5AT looks like
http://imageshack.us/photo/my-images...100800006.jpg/
Old Oct 18, 2011 | 10:57 AM
  #47
http://imageshack.us/photo/my-images...100800007.jpg/
Old Oct 24, 2011 | 02:43 PM
  #48
muhtish's Avatar
Thank you Lost180 for posting my pics, and GHETTOGRAMMA for sharing your pics!
So by the looks of it when someone was putting my car together (it had damage in the front when I bought it) they put a different model Navi.
Any suggestions where I can find a used navi for 06 coupe?
Old Oct 25, 2011 | 12:17 PM
  #49
Any suggestions where I can find a used navi for 06 coupe?[/QUOTE]
i would say check ur local junk yard its cheaper dan ebay
canada and us
http://www.standardautowreckers.com/
saw it here for $234
Old Oct 25, 2011 | 09:23 PM
  #50
muhtish's Avatar
What would it be under. I didn't see it under that Navigation?
Old Oct 25, 2011 | 09:43 PM
  #51
ok click link chose country CDN OR US den on top nex to home click
PART SEARCH>>DIRECT FIT PARTS>>>SELECT YEAR>>>MAKE MODEL
and for PART SELECT go down to GPS SCREEN den hit search
den go to PLAYER (NAV,DVD)
and dats it right derrrr
Old Oct 26, 2011 | 08:35 AM
  #52
chuyanna's Avatar
I have the same problem with my 05 G35X, the dealer charged me 90 to tell me it did not work, the wanted 875.00 to fix it, I took it to a body shop, the took the dashboard apart, did not find anything wrong, cost 100.00 for nothinh, it still just goes up and comes right back down and the screen is black, HELP. Thanks
Old Oct 27, 2011 | 09:33 PM
  #53
Trickstyle's Avatar
idk if it was this post or another(its been a few weeks since ive been on Driver) but I remember someone saying something electrical was powering up intermittently. they ended up just cleaning off the contacts of the fuses that were installed. I guess they became corroded or whatnot after a while? idk... it worked for him/her though. GL tho!
Old Nov 1, 2011 | 12:16 AM
  #54
muhtish's Avatar
Thank you for putting some time into it to look it up what it was under. I appreciate it!
I have found a website that is a little bit more inclusive, junk yard wise...called car-partsdot com
Old Nov 1, 2011 | 12:20 AM
  #55
muhtish's Avatar
When the shop took your dashboard apart, did they also take the glove box apart?
If they didn't, then there might be a chance that your connectors are loose or might not be plugged in, even (as it was in my case).
Did your Navi worked at first and then started acting up or what?
Old Nov 11, 2011 | 12:45 PM
  #56
Originally Posted by PsychoMus
So I have the '03 coupe. And my Navigation works sometimes since I first got it back in 2009. I have come to the conclusion that it only works when the temperature outside is hot. I don't know where you guys live...but in the Summer time my NAVI works just fine. And when the Fall and Winter arrives its dead. I noticed this during the winter while it was dead for some time...then one day the sun was out and outside was about 70 degrees and the NAVI powered up. By the afternoon, once the sun went away and the temperature cooled down the NAVI died.. This is the way it works in my car...Alive in the Summer, dead in the Winter.
Anyone else experience this?
hey i replaced the dvd nav rom and it works all the time now bought 1 from ebay for 230 shipped maybe it will work for u too
Old Nov 11, 2011 | 12:48 PM
  #57
ok glad u found something ah lil easy but its under the gps screen hope u find wat u lookin for
Old Nov 29, 2011 | 09:48 PM
  #58
muhtish's Avatar
Thank you guys for all your input.
My car is finally painted and I have it all together other than spoiler and side skirts on.
OH and of course had to take my Navi out and, sure enough it was one from 05. Now time to register the car and then search for Navi.
Oh and I was going to post some pics of my G as it progressed when I bought it wrecked, but lost my folder will all of pics
Old Nov 29, 2011 | 10:39 PM
  #59
muhtish's Avatar
Ok Just wanted to double check with you guys. Does 07 navi fits 06 or do I need a specific 06 unit for G35?
Found this guy on ebay...is this the unit that is above glove box?
http://www.ebay.com/itm/07-10-Infini...item53ea351936
Old Nov 29, 2011 | 11:41 PM
  #60
LoSt180's Avatar
A 2007 COUPE Navi control will fit, a 2007 SEDAN is different and therefore not compatible.
The link you posted is for the Display from an Armada, don't think that's what you're looking for.
