"Thumping" from rear wheels.
Old Jul 1, 2011 | 12:31 AM
CharlesHubular's Avatar
Hey guys and gurus, so i've been having a problem. For the last 200 miles or so when I get the car up to 40+ and get off the gas and coast I am SOMETIMES getting a "thumping" sound and vibration from the rear tires. Recently the sound has come more frequently and strongly. I am relatively sure it is something on the rear of the car causing the problem because there is no shake to the steering wheel. I can feel it shuddering through the wheel but that is because of the intensity, it shakes the hell out of the rearview mirror as well. The best way I can describe the thudding is as if I had a flat spot on one of my tires, it increases with speed and sometimes stops for a while after I come to a stop. This ONLY happens when coasting, but then continues afterwards for the rest of the drive.
So far I have had all four wheels and tires balanced, and recently gotten a four wheel alignment (lifetime alignments FTW), I know I need a rear wheel bearing but when talking to the Nissan techs they said that theyve never heard of a bearing causing a shudder or thud as I described. Problem still persists.
At the beginnning of this season I put the car on Eibach Pro Kit springs (kept the stock shocks), and installed spc front and rear camber kits and toe bolts.
As I mentioned I am having the rear passenger bearing replaced next week, but I am not getting my hopes up on this solving my problem.
ANY imput would be great. Help me out so I can stop shakin and start shining! If I remember anything else I will edit.
Thanks a million boys.
Old Jul 1, 2011 | 09:18 AM
rimshaker's Avatar
Had a big nail in my rear tire once, but that only caused an annoying clicking/thumping sound, no shaking or shuddering like yours.
Old Jul 1, 2011 | 02:57 PM
AuAltima3.5's Avatar
Thumping that goes away under braking? ... Check all your bushings and pivot points. Wheel bearing should repair should help you narrow down during repair (check everything!)
I would also check the driveshaft, u-joints, and drain the diff to see if any broken gears are floating around in there.
Old Jul 1, 2011 | 03:03 PM
Thank you I will definitely check all of the above when the bearing is changed. But to clarify, the thumping can be felt DURING breaking, but after coming to a stop and then moving again it sometimes stops.
Old Jul 1, 2011 | 04:46 PM
mistuhlayzee's Avatar
I have the same noise but in my case its like a small vibration coming from the rear and like very low thumping, I'm thinking its my exhaust because I went to get my mufflers aligned and I reversed over a steel pipe and ever since its been making low rattling noises in the rear/shaking. Any suggestions?
G35VSHNG37
Oct 25, 2015 08:43 PM
Jiggerjuice
Aug 17, 2015 08:41 AM
friedsqrl
18 Inch
11
Aug 9, 2015 12:41 PM
