Is there a good way to check tranmission fluid?
Old Jul 2, 2011 | 11:50 PM
Cooldude04's Avatar
Hi everyone
I recently changed my automatic tranmission fluid by following the DIY from thebayplayer. Everything went good except for checking the fluid level. It drives me crazy. I start the engine, let it warm up 5 mins and check the level with car in park and the engine running but the damn fluid was all over the dipstick and I didn't even know if it's above the H level or below.. The fluid was all over the dipstick... Does anyone know a better method to check it? I tried searching but still couldn't come up with a more accurate way to check it. Please help.
Old Jul 3, 2011 | 02:36 AM
AuAltima3.5's Avatar
I've had the same issue. I used to use the "if I drained X qts, add X qts" until I added my trans cooler. Then I didn't know.
Now I do this: If the car is running and it's 60-70F out, I make sure the fluid reaches about 3-5mm below the lowest notch. The FSM says the fluid should be between the two notches around 89-122F. I suppose if it's a hot day you could start your car and immediately check the level. that's what I do since any driving or extended idling make the splashing worse, and it's definately a no after filling.
Old Jul 3, 2011 | 02:58 AM
thescreensavers's Avatar
Mr.202?
Hmm, I checked my fluid by simply, driving home(30miles) opened the hood took the dipstick out with the car running and wiped it put it back in and took it out, no issues.
Old Jul 3, 2011 | 06:39 AM
Blue Dream's Avatar
I drove ttrank's car solo
Same for me^^
Oil dipstick that's a whole other story.
Old Jul 3, 2011 | 06:53 AM
Cooldude04's Avatar
I did pump out the old fluid from the tran cooler. Could that cause the problem??? it was around 75 degree yesterday. I'll try to check it again today
Old Jul 3, 2011 | 06:54 AM
Cooldude04's Avatar
thanks for the reply guys. I'll try to drive a long distance today and check it as soon as i get back home. Hopefully, i can get an accurate reading.
3000vr4tt
Media Share V36 Sedan
Jan 4, 2023 03:20 PM
Jusseth
Sep 13, 2020 12:25 PM
hdmark
Apr 29, 2019 04:31 PM
TurboEE
Jul 31, 2015 10:41 AM
bickfordbft
Jul 20, 2015 07:57 PM
