Engine coolant - which type to buy?
Old Jul 18, 2011 | 10:45 PM
GuyLegend's Avatar
Searching around, the only info I found is to use a ethylene glycol silicate free coolant. Is that the equivalent to the standard Nissan/Infiniti coolant?
Just wondering what to buy for the g coupe since my coolant seems to be low.
Old Jul 18, 2011 | 10:52 PM
cto917's Avatar
are you just adding coolant or doing a full exchange? if its just refilling it, just get some prestone coolant, i think its green in color and it will work, if you're not extremely low just put some distilled water in there if you're not in near freezing temps.
but yes, when buying coolant silicate free seems to be the most important thing for our cars. oh yea, no dex cool either.
Old Jul 18, 2011 | 11:48 PM
brandon1978's Avatar
Prestone Extended Life in the yellow bottle is silicate and phosphate and a couple other 'ates free. It works well in my G.
Old Jul 19, 2011 | 12:16 AM
dEnbOy.GFM's Avatar
I use none other than:
Old Jul 19, 2011 | 01:16 AM
GuyLegend's Avatar
Thanks for the info guys. I'm just refilling the reservoir, not changing out the entire fluid. I just had the radiator flushed from the dealer recently, but the coolant level is near the minimum.
I could go back and hassle them to fill it up, but I figure I should have my own bottle of coolant anyways. I'll look for a silicate free Prestone solution at a local auto store.
Blakearold
Aug 27, 2015 12:37 PM
Phenomenon9
Aug 9, 2015 01:34 AM
joedaddy1
Jul 28, 2015 02:58 PM
ClwMike
Jul 23, 2015 12:55 PM
