G35's power train warranty
Old Jul 20, 2011 | 02:05 PM
hologram's Avatar
What exactly is covered under that warranty? Is suspension/bushings, drive axle and stuff like that covered? I did try to read up on it but couldn't find a definite answer.
Old Jul 20, 2011 | 04:34 PM
dEnbOy.GFM's Avatar
From the Nissan manual...
■ POWERTRAIN COVERAGE
• The Powertrain coverage period is 60 months or 60,000
miles, whichever comes first.
• This warranty covers any repairs needed to correct
defects in materials or workmanship.
• Powertrain coverage applies to components listed below,
supplied by Nissan except for those items listed
under the caption “WHAT IS NOT COVERED”.
ENGINE
Cylinder heads and block and all internal parts, rocker
covers and oil pan, valve train and front cover, timing chain
and tensioner, oil pump, water pump and fuel pump, fuel
injectors, intake and exhaust manifolds and supercharger,
flywheel, seals, and gaskets.
TRANSMISSION AND TRANSAXLE
Case and all internal parts, torque converter and converter
housing, automatic transmission control module, transfer
case and all internal parts, seals and gaskets, clutch cover
and housing, and electronic transmission controls.
DRIVETRAIN
Drive shafts, final drive housing and all internal parts,
propeller shafts, universal joints, bearings, seals and gaskets.
WHAT IS NOT COVERED
DAMAGE, FAILURES OR CORROSION DUE TO
ACCIDENTS, MISUSE OR ALTERATIONS
This warranty does not cover damage, failures or corrosion
resulting from:
■ Accident, theft, fire, driving through water (including engine
water ingestion) or misuse (Proper use is outlined in
your OWNER’S MANUAL).
■ Alteration, tampering or improper repair.
■ Installation of non-Nissan approved accessories or components.
■ Improper installation of any Nissan approved or aftermarket
accessory or component.
■ Glass breakage, unless resulting from defects in material
or workmanship.
ALTERED OR UNCERTAIN ODOMETER MILEAGE
This warranty does not cover repair of any vehicle or any part
of a vehicle of which the odometer mileage has been altered,
or the odometer repaired or replaced and the actual vehicle
mileage cannot be correctly and readily determined.
SALVAGE TITLE
This limited warranty does not apply to any vehicle, and is
rendered void if the vehicle is (or ever has been) issued a
“salvage” or similar title under any state’s law; or has ever been
determined to be a “total loss” or equivalent by any insurance
company, such as by payment of a cash payment of claim in lieu
of repairs because of a determination that the cost of repairs
exceeded the actual cash value of the vehicle.
DAMAGE, FAILURES OR CORROSION FROM
ENVIRONMENTAL CONDITIONS
resulting from:
■ Stone chipping, chemical fallout (acid rain), tree sap, salt,
hail, wind-storm, lightning, flood or other environmental
conditions.
■ The items listed below are not covered under corrosion
coverage (perforation from corrosion).
• Exhaust system components.
• Corrosion of outer trim parts, such as moldings. However,
corrosion of outer trim parts is warranted for
12 months or 12,500 miles, whichever comes first.
• Corrosion other than perforation, such as cosmetic
or surface corrosion due to defects in materials or
workmanship. This is covered under the Basic Coverage
of the New Vehicle Limited Warranty.
• Special bodies or equipment not manufactured or
supplied by Nissan.
LACK OF OR IMPROPER MAINTENANCE
resulting from:
■ Lack of performance of proper maintenance services as
outlined in your NISSAN SERVICE & MAINTENANCE
GUIDE.
■ Use of improper or dirty fuel, fluids or lubricants.
■ Use of parts not equivalent in quality or design to parts
supplied by Nissan.
MAINTENANCE SERVICE EXPENSE
This warranty does not cover normal maintenance services
as specified in your NISSAN SERVICE & MAINTENANCE
GUIDE such as engine tune-up; cleaning and polishing;
wheel alignment; headlight aiming; replacement of filters,
replacement of windshield wiper inserts, lubricants, coolant;
worn brake shoes, pads, drums and rotors and worn clutch
discs.
SEAT BELTS, TIRES, TRUCK BEDLINERS, AND
EMISSION CONTROL SYSTEM
Seat belts, tires, truck bedliners, and the emission
control system are not covered by this warranty, but
are covered by separate warranties.
(See following pages for separate warranties which may
apply to your Nissan, such as those covering vehicle emissions,
seat belts, and tires.)
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
newbdriver01
Jul 15, 2015 06:10 PM
