strut won't come out, still feels like its under pressure
Old Aug 3, 2011 | 07:02 PM
IIIHawKIII's Avatar
ok, i'm trying to get my strut out to swap springs...i've followed the DIY and the youtube video, but for some reason, my strut isn't moving freely like the video. it's like it's still got a load on it.
i'm a big guy and i'm yankin on this thing like there's no tomorrow and i cant get it out. it won't come down from where it meets the body at all. like when it says to "slide the lower fork forward" my fork won't move. i mean, if i STEP on the control arm, then it might, but i don't want to break anything...
how hard can i shove down on the control arm assy? but it doesn't seem like it would matter because it's held in place by the lower endlink....should i try and get the lower control arm off of the endlink?
any help is appreciated.
Old Aug 3, 2011 | 07:10 PM
LordFappington's Avatar
You wont break it, you need to pull down on it pretty hard to bring out the strut. Your other option is to remove the LCA.
Old Aug 3, 2011 | 07:14 PM
chink-ah-saur's Avatar
use a bar of some sort, like if you were you pry it up and out.
Under the fork.
And ar you doing one side at a time?
Old Aug 3, 2011 | 07:19 PM
4D05G35's Avatar
Did you unbolt the swaybar endlink? If not, unbolt that from the LCA and everything will drop down and fall out.
Old Aug 3, 2011 | 07:23 PM
IIIHawKIII's Avatar
i took the nut off of the endlink....and tried to slide it back thru the other way, but it won't slide out of the LCA.
thanks for all the super fast replies. i'm bout to go hulk smash this thing....
yeah, i'm doing one side at a time.
Old Aug 3, 2011 | 07:24 PM
If you break your endlink, replace it anyhow the stock ones suck.
Old Aug 3, 2011 | 07:25 PM
IIIHawKIII's Avatar
the rusty bolt there on the right...how do i get that to back out? should i jack up the control arm assy and try and push it backwards? or bang on it with a hammer? that seems like it would chew the threads up....
Old Aug 3, 2011 | 07:27 PM
Slightly jack up your LCA until its not totally hanging on the endlink. Back it out with a hammer.
Lift the whole front end up, then wd40 were fork is, then use pry bar or thick screwdriver, up & over
Old Aug 3, 2011 | 07:32 PM
IIIHawKIII's Avatar
DAAHHHHHARHARHAR HAVE YOU SEEN MY BASEBALL??
i got it. needed to jack up the whole assy so the bolt wasn't all cockeyed in the hole.
bring on the facepalm gifs.
Old Aug 3, 2011 | 07:39 PM
lol you said cockeyed.
Old Aug 3, 2011 | 07:42 PM
IIIHawKIII's Avatar
did you hear about the kid that was born with no eyelids?? they skin grafted some of his foreskin on there...went really well, but he came out a little...........
Old Apr 2, 2012 | 12:19 PM
woodsean157's Avatar
im currently having the same issue, tension it seems like on EVERYTHING... the endlink bolts are so crooked its impossible to get them out, as well as the lower bolt for the strut assy... all im trying to do is replace the upper control arms but the eibach springs are in the way so i need to lower/move the strut.. what is wrong with the thing...
Old Apr 2, 2012 | 02:53 PM
Golfpro1's Avatar
I did mine last weekend. Remove the bolt connecting your LCA to your rotor assembly. Move the rotor out of the way, and remove the bolt to your end link. Then jack up the LCA to straighten out the end link bolt and it should come right out, then you will be able to lower the jack, drop your LCA and remove the strut
jsimonk
Dec 22, 2023 03:49 PM
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
nosam1g
Aug 22, 2015 11:58 PM
