connecting amp to battery
hey guys, i posted in the tech section and never got a response i really understood. how do you guys connect the and aftermarket amp power wire to the battery? the stock positive terminal is tight and any ring i try to slip in doesnt fit. currently i have bare wire touching the positive terminal and i know this isn't the best way. so...any help would greatly be appreciated. pics would be great too. thanks.
The ring u need to put on where u tighten the bolts. unscrew the bolt or nut all the way off then slide on the ring then tighten nut or bolt back on. ill try and find a pic for u in the evening
awesome, thanks man. really appreciate it
There was this external case thing over the positive terminal in my car and had a very obvious place to place the ring terminal. I bought the car used with a viper alarm installed so I'm not sure if that's stock but it should be very simple as others said.
