Clearcoat question
Old Aug 22, 2011 | 06:21 PM
MADtotheA's Avatar
As promised, here is the final result. I am very pleased with the outcome. I can honestly say, I will never do this again! It took FOREVER!!!
Thanks to those that helped giving me tips! It worked out perfectly!
These pics are from my iphone so they don't show the "shine" like it should. They are very glossy and look amazing in person though.
Old Aug 22, 2011 | 06:33 PM
IIIHawKIII's Avatar
so did you just get closer? or what? and did you scotch them all the way thru the paint and start over?
regardless...glad we could help.
Old Aug 22, 2011 | 06:49 PM
MADtotheA's Avatar
Yup got a little closer. Scotched the back rims lightly but never broke through the paint so I just clear coated them and they came out great. I think the temperature where I'm at is causing the clear coat to dry so I think that is why I needed to spray a few inches closer.
Old Oct 6, 2011 | 04:51 PM
MADtotheA's Avatar
Ok, sorry to bring this thread back up but I am still unpleased with my back wheels. They are no where near as glossy as my fronts are. Now that it's been a little over a month, would it be safe to try and re-apply a clear coat to them? I'm guessing I should scotch pad first then wipe clean, then apply the clear coat. Also, I no longer have my friends floor jack or jack stands so would it be a bad idea to do this while on the car? Obviously I would put a ton of newspaper behind the wheels so the calipers and rotors are safe and also I would cover the entire area of my car that is anywhere near the tire. Bad idea? or should it be fine as long as I tape everything off VERY well. Thanks guys
Old Oct 7, 2011 | 03:28 PM
MADtotheA's Avatar
no input? come on, someone knows about this!!
Old Oct 18, 2011 | 12:24 AM
fchdx's Avatar
Yeah just take the clear coat off as best as you can. It's fine if you just apply it onto the wheel without it jacked up, just mask it off really well.
Old Oct 18, 2011 | 02:20 AM
G35SedanGrn's Avatar
DO NOT PAINT IT ON THE CAR!!!!!!!! YOU WILL GET OVERSPRAY EVERYWHERE EVEN IF YOU TAPE OFF! the only way to not get overspray is if you tape off the whole car. wind will carry the paint.
Old Oct 18, 2011 | 11:51 AM
MADtotheA's Avatar
Ok ok!!! Haha I've decided to just buy some 20's and sell these anyway. I'm done messing with them.
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
migurus
Sep 5, 2015 09:39 PM
UT G35
Sep 3, 2015 03:58 PM
TheBay
Sep 3, 2015 03:27 PM
erich2780
Sep 3, 2015 03:23 PM
