Underhood noise after part install
Old Sep 4, 2011 | 10:41 AM
sickTTG35ry's Avatar
Ok I have seen alot of post on various site about this type of problem, but mine is a little different question.
I installed the JWT pop-charger with the Motordyne spacer w/Iso thermal gaskets. I had no problems with either install. I put the pop-charger on a day before I installed the spacer. As I know from previous after market intake installs the intake air sound gets louder. I noticed a little whistle from the pop-charger which is normal. However the next day after the spacer/ ISO gasket install I noticed the whistle was noticeably louder and could be heard (only if you were listening for it) while driving down the road with the windows up. First thing I thought vaccum leak. So I rechecked all the bolts to specs all were good. Had my girl rev the engine to produce the sound while I sprayed carb cleaner around the TB and intake mani. Nothing! The sound was coming only from the air filter. I just wanted to know if anyone that had done these two mods noticed the whistle get louder.
Old Sep 4, 2011 | 10:45 AM
PAIXAO's Avatar
As long as you dont have any leaks in the plenum, I wouldnt worry about it. Check the rubber around the oil filler cap as its a common area to get pinched between the spacer.
Old Sep 4, 2011 | 07:00 PM
Blue Dream's Avatar
I drove ttrank's car solo
The spacer increases the amount of air entering the plenum so you should expect more of a whistle. If you checked thoroughly for leaks and found none, relax. The new sound is normal, enjoy the hell out of it.
Old Sep 4, 2011 | 09:14 PM
Thanks guys, yeah the oil filler rubber is good. And that is what I figured would cause the increase in the whistle. I guess I am just being paranoid. Thanks for the replies. And keep on modding Blue, sounds like a good idea I hear huggies are really comfy.
Old Sep 4, 2011 | 09:18 PM
Blue Dream's Avatar
.....lmao.......
Old Sep 4, 2011 | 10:02 PM
gary c's Avatar
Word of caution....never, ever spray carb cleaner on your engine! I'm surprised you're still around to make this thread, carb cleaner is extremely volatile/hot all it takes is one spark. You could have got the same results using WD40 looking for a vacuum leak.
Gary
rezendvous420
May 31, 2020 01:26 PM
atk08
Jul 30, 2015 03:12 PM
Jussaku
Jul 29, 2015 11:45 AM
joedaddy1
Jul 28, 2015 02:58 PM
rping
Jul 26, 2015 09:53 PM
