Question! Help!
Question! Help!
After doing some random work to my g today (2006 coupe), i noticed some...lag in my driving. When my rpm's hit about 2, my car jerks back a little. Almost as if the ebrake was on. I know the ebrake isnt stuck because i took it apart and looked but i read it could be the mass airflow sensor? That would make sense because i cleaned my throttle body and mas today but i did it how i normally would. Sprayed it with proper cleaner and let it dry. A code did come up because my buddy turned the key on while it was unplugged so im going to clear it tomorow. Is there anything i can do to fix this? Or is my maf just broken... Everything is pluged in so maybe will it fix itself once i clear the code? If its broken, where is a good place to get a good aftermarket mas?
Thanks guys!
And sorry for the long description..
Thanks guys!
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
