HID Help!
Old Oct 2, 2011 | 08:18 PM
G35AndTGOD's Avatar
HID Help!
So I ordered my 10k HID's I have stock ones currently I was told all i need was the bulb so i got em for 22 bucks is that true? or do I need more peices? and if so were do i get em from thanks!
Old Oct 2, 2011 | 08:30 PM
ThatOneDude's Avatar
Depends; What year G35 do you have? If yours is 2005 orlower, you will need more. If it is 2006 or higher, you'll be fine. Good luck replacign it, since clearly you did nto do your research >.>.
TYPO'S BUT W/E
Old Oct 2, 2011 | 10:18 PM
Tabris's Avatar
Aww.. were they all out of the cheap lights?
10K..
Old Oct 2, 2011 | 11:37 PM
I dont' think temperature affects price, or says anything at all about budget. nt.
Old Oct 2, 2011 | 11:43 PM
Xet's Avatar
Xet
Depends on what bulbs you got, and what year your car is. If you didn't get the right bulbs for your year then you aren't set. 10k is so dark and ricey...
Old Oct 3, 2011 | 11:56 AM
G35AndTGOD's Avatar
TYPO'S BUT W/E
So with my 05 what part would i need
Old Oct 3, 2011 | 12:38 PM
Do you know what bulb part number you got? You might not need anything else, actually. I kind of had a brainfart, thinking the reflector headlights didn't have ballasts for HID support.
Old Oct 3, 2011 | 01:05 PM
10splaya22's Avatar
Should be plug and play no matter what year. The 03-05 uses a D2R while the 06+ uses a D2S
And you should stick with 6000K or less, any more and it gets ricey
Old Oct 3, 2011 | 03:34 PM
Tabris's Avatar
OEM/Decent quality affects price. Phillips makes 4300k and 6000k bulbs, and you pay for quality. Once you start buying 8000k, 10000k bulbs from "somewhere" china you are getting lesser quality.
Old Oct 3, 2011 | 09:04 PM
G35AndTGOD's Avatar
They are D2C
Old Oct 4, 2011 | 02:03 AM
10splaya22's Avatar
Originally Posted by G35AndTGOD
They are D2C
Sylvania's site says D2R. Put the model in here: http://www.sylvania.com/ConsumerProd...lacementGuide/
2004 INFINITI G35 (With HID (high intensity discharge) headlamps)
Low beam headlamp
HID-D2R
Also, this site says the same: http://plasmagarage.com/info_InfinitiXenonHIDBulbs.html
And then I read this:
What is D2R, D2S and D2C?
D2R, D2S and D2C are all HID's bulb sizes. D2S bulbs are made for vehicles with projector headlight housings such as BMW 3 Series, Honda S2000. D2R bulbs are made for vehicles with reflector headlight housings such as Lexus IS300, Infiniti G35.
D2C bulbs is a new version invented in Japan. It is universal fit for both D2S and D2R housing.
3 Actual Photos of our D2C bulbs.
So I guess D2C can be used in both?
Old Oct 4, 2011 | 08:58 AM
G35AndTGOD's Avatar
Well I'm not to sure I checked other places and it said they could but I come to the forums to make sure if the D2C fit or not.
Old Oct 4, 2011 | 08:59 AM
G35AndTGOD's Avatar
And I don't know if you do or don't need a conversion kit!? Some people say you do some people say its as easy as pluging it in without one?
Kelvin Style006
May 23, 2016 03:47 AM
heynow
2nd Gen (V36) Sedan
Oct 28, 2015 05:09 PM
MrIP35
Oct 25, 2015 11:13 PM
G35-2004-mt6
Sep 11, 2015 04:16 PM
twentyeggs
Sep 11, 2015 03:58 PM
