HELP! I'm stuck in my trunk!!
Old Oct 3, 2011 | 02:05 PM
04G35blackcoupe's Avatar
Ok i'm not really stuck...in fact I can't get stuck cuz i can't get in my trunk. My trunk does not open with my FOB or with the opener on the inside of the car.
I've read a few threads about the wire being cut a lot but before I check that, i was wondering if anyone knew what fuse is used....I have attached a diagram. This was from the fuse box by my clutch...not under the hood.
Thanks!
Old Oct 3, 2011 | 02:12 PM
MADtotheA's Avatar
Thanks!
If I'm not mistaken, the fuse is the same one used for the brake lights. Also, in your back seat, there is a trunk release handle.
Old Oct 3, 2011 | 02:13 PM
redpearl99's Avatar
reach in between the middle of the rear seats and you'll find a red strap. it's the emergency trunk release
Old Oct 3, 2011 | 02:18 PM
EDGAR's Avatar
you can gain access to it by pulling the red string on the backseat then pull the backrest part of the seats down once you do that you can manually open the trunk by pulling the "T" looking thing
GR6RR's Avatar
^ yep! that's it! red strap!
Dallsinghjr1
Sep 17, 2023 11:25 AM
ara777
Oct 25, 2017 01:45 PM
g.spot
May 9, 2016 10:54 PM
G35xdriver04
Nov 7, 2015 08:31 PM
