battery relocation ?
Old Oct 7, 2011 | 09:24 PM
herrschaft's Avatar
You can go with a taller geared differential
Old Oct 7, 2011 | 09:27 PM
g35915's Avatar
yea i was thinking that eitheir 3.5 or 3.7 but how much mpg do you lose for 3.7 i know 3.5 not much at all
Old Oct 7, 2011 | 09:32 PM
herrschaft's Avatar
^I don't calculate MPGs, so IDK.
Old Oct 7, 2011 | 09:44 PM
ThatOneDude's Avatar
Actually, wouldn't relocating the battery to the rear also add to the total weight of the car?
Old Oct 7, 2011 | 09:45 PM
zackt69's Avatar
rarejdm.com
We relocated mine to the trunk. You'll want to get some sort of battery tray and mount it securely to the trunk. Depending on what kind of battery you use, and if you are going to race, you may need to have an enclosed battery box and covers for the terminals (if you run a Optima battery, a closed box is unnecessary). Also, be sure you move the fusible link to the trunk as well, otherwise the length of battery cable running from the trunk to the engine will not have a fuse on it and could be dangerous if it somehow becomes exposed to a grounded surface.
Here's a sample kit:
http://www.summitracing.com/parts/SUM-G1230-K/
Old Oct 7, 2011 | 09:54 PM
g35915's Avatar
got any pictures of it done ?? did it help any and is it easy to move the fuse box ?
Old Oct 7, 2011 | 10:03 PM
zackt69's Avatar
rarejdm.com
While it is better for the overall weight balance, you honestly won't notice any difference.
You don't need to move the entire fuse box, just the fusible link (that large positive connector on the battery has a huge fuse on it). I'll try to get some pics tomorrow... my car is at the dealership.
Old Oct 7, 2011 | 10:11 PM
g35915's Avatar
alright kool thanks
Old Oct 8, 2011 | 04:22 AM
TemjinX2's Avatar
most oems put the battery on the passenger side to help offset the fact that your body weight on the driver side upsets the overall weight balance of the car. Think about it, you sitting in the car, adds 160-200lbs to the whole left side of the car.
If your trying to get performance, you should really be trying to corner balance your car.
Old Feb 24, 2012 | 10:23 PM
NYT's Avatar
NYT
Informative post - thanks. Post any pics if you can please.
Where did you run the wires to the trunk.... under the car... thru the cabin?
Old Feb 25, 2012 | 09:05 AM
grovefromnh's Avatar
Back when I was roadracing a Camaro, the GM race prep manual said moving the battery to the trunk (approx 12') was equivelent to moving the engine/trans back a whole foot. Any weight off the frontend is a good thing.
KruZZe
Feb 27, 2023 05:04 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Thebaws11
Nov 30, 2016 12:54 PM
g.spot
May 9, 2016 10:54 PM
dcsbh1
Oct 1, 2015 03:15 PM
