How much have you spent on Suspension?
Old Oct 13, 2011 | 03:49 PM
  #31
walshtj's Avatar
Zero so far, lol still stock height.
Old Oct 14, 2011 | 12:55 AM
  #32
LR-G's Avatar
BC Racing Coilovers 1500$ (2years ago)
SPC Camber Kit 150$ (2years ago)
Install 200$
Alignment 99$ still the same today.
My tires lasted me about 2 years. about the same time as my OEM ones.
Old Oct 14, 2011 | 12:58 AM
  #33
2K6G35c's Avatar
Exact same here. And loving it. tires don't wear out to quick when you leave the suspenion stock.
Old Oct 14, 2011 | 01:14 AM
  #34
MADtotheA's Avatar
Great contribution
Old Dec 30, 2012 | 09:50 PM
  #35
Davidle92's Avatar
So far living that stock life but im having clunking sounds from the passenger side rear, i really hope its something simple i can do myself like a bushing replaced. Any inputs?
Old Dec 30, 2012 | 09:56 PM
  #36
Gdriver90's Avatar
Camber kit F+R T $525.00
SPC toe bolts $44.00
install $250.00
Project Kicks Neo Nuts $220.00
Lifetime Alignment $120
Wheels + Tires $6000
BBK $2k
Front/Rear sways $300
Kw V2 Coils $1800
Total:$11,259 give or take. DAMN now im depressed
Old Dec 30, 2012 | 10:04 PM
  #37
Shanes_G's Avatar
What wheels do you have?
Old Dec 30, 2012 | 10:08 PM
  #38
Gdriver90's Avatar
Savini Sv25's
Old Dec 30, 2012 | 10:21 PM
  #39
herrschaft's Avatar
Tallied everything up again and now at $6K.
Old Dec 30, 2012 | 10:31 PM
  #40
Revo's Avatar
So far:
Stillen Sways $400 Installed
KW V3's $2300 Installed
SPC Rear Camber Kit/Toe Bolts $300 Installed
Replace Compression Rods $500
Total: ~$3500
Still need to do:
SPC Front Camber Kit
Adjustable Sway Bar Links Front and Rear
Bushings all around
So, in short, how much have I spent? Too much and not enough, apparently.
I just included pure suspension parts. Some of you guys are grouping in brakes and wheels/tires. Wheels and tires...maybe. Brakes...are just brakes. I'm running stock rims and tire sizes anyways.
Old Dec 30, 2012 | 10:55 PM
  #41
alfhasg35's Avatar
HKS Hypermax 3's $1350 (used)
SPL V3 FRONT camber arms $650
SPL REAR camber arms $250
Stillen Sways $300
PowerGrid Endlinks $325
SPL upper, lower control arm and Compression Rod bushings $450ish
SPC Toe Bolts $30
Fender Rolling and Pulling $200 ish
Alignment and Corner Balance $350 ish
None of the prices incl. install..
Close to $4k without install..
strut bar too.. ARC .. does that count...? not really..
Old Dec 30, 2012 | 11:33 PM
  #42
Revo's Avatar
^ Aftermarket strut bars count. In which case, add another couple hundred for my Stillen Strut Bar in my trunk...
Old Dec 30, 2012 | 11:52 PM
  #43
gary c's Avatar
There are a few things you need to know before you start dropping big $$ on your suspension. Know what you're buying and what the results will be. I wasted more than a few $$ on buying the wrong adjustable a-arms which didn't give me enough adjustment to get back to OE alignment specs. So I had to buy the latest SPLs, have them installed and get another alignment. I was lucky to act quickly so my front Michelin's didn't suffer....much! Don't buy anything until you've done extensive research, it will save you a bundle....Gary
Old Dec 31, 2012 | 12:00 AM
  #44
Revo's Avatar
Which arms did you have before that didn't have enough adjustment?
Old Dec 31, 2012 | 12:09 AM
  #45
gary c's Avatar
I believe they were called Cusco's.
