Big problem! Help!
Old Oct 14, 2011 | 07:35 PM
Kikal8's Avatar
Big problem! Help!
ok.. so my brother has an 05 g35 coupe with the suspension and navi and 19inch wheels and watever ha. so.. he comes home today and his driver side window goes up and down no problem. he got the passenger side window stuck down. now ive read all the crap about the actuator and motor things. but i dont hear ANYTHING when you try putting the window up. the switch is lit up and watever. but its like a fuse is blown. nothing happens at all. no noise no nothing.
now the second thing is that his power door locks from INSIDE the car do not work either. either side. he says that both the windows and the locks stopped working at the exact same time and he says that there was no slow window movement at all before. so im quite lost. im thinking simple like a fuse. but could be wrong. anyone please help. ha we were out there checking fuses under the hood and it began raining. so we were soaked. now im inside doing some research. if anyone can help id appreciate it.
thank you.
Old Oct 14, 2011 | 08:37 PM
Glex25's Avatar
Administrator
There are 2 fuse boxes in the battery compartment and another by the driver side footwell.
Check all fuses since that is what it seems like
Drifter2090
Dec 26, 2015 12:10 AM
Mick_L
Aug 25, 2015 04:27 PM
Phenomenon9
Aug 9, 2015 01:34 AM
