removing stock grill.
Old Dec 20, 2004 | 07:12 PM
g35sammy's Avatar
can someone tell me how to remove the stock grill on the g coupe? i took all the little bolts off and pressed down the tabs inside the grill but the ends are stuck together....is that just double sided tape? please help!!! thanks
Old Dec 22, 2004 | 04:46 PM
chinkstylzz's Avatar
i can't get the hidden clips out on the top sides. can anyone help.
Old Dec 22, 2004 | 07:05 PM
NYCXLR8's Avatar
This is a little tricky... I used a long thin flathead screwdriver and inserted it in the left and right side clips. This allowed you to go into those slots and release the clips that are in there. Once each clip is released the grill comes out cleanly.
If I can find my install directions from the gialla, I will post it somewhere for you... no promises on that one though
Old Dec 22, 2004 | 07:09 PM
NYCXLR8's Avatar
Took a look and couldnt find it... sorry.
Old Dec 22, 2004 | 09:07 PM
i used a flat head, should i just push as hard as possible or will a clip pop off? I heard your suppose to twist the flathead but i dont know where to put the flathead.
Old Dec 23, 2004 | 12:34 AM
NYCXLR8's Avatar
There is a square screw head inside the slot. Use a flashlight and shine it in the hole. You will then be able to see what you are aiming for. I did not even notice the head of the screw (plastic btw) prior to using the light. All you have to do is give the screw a 1/4 turn to get the square shape of the screw head to lign up with the shape of the hole (one is offset, think of it as a square standing on one of it's points). Hope that helps.
Old Dec 23, 2004 | 03:46 AM
g35sammy's Avatar
its there....if you look at the right and left sides right abot the grill......there is a hole.....if you look through there there is a little square screw, you have to get a flat head that fits in there and turn it 1/4 of the way left of right and then pull the grill.....took me a while to find it as wel.....good lck man!
skippyG
Jan 25, 2016 01:18 PM
broke_as_ajoke
Aug 22, 2015 08:27 PM
andrewvk
Interior
Aug 6, 2015 05:51 PM
