Driver's door lock/escutcheon coming out.. fix?
Old Oct 23, 2011 | 05:13 PM
cpufreak3's Avatar
My driver's side door lock is coming out... Here's how it hangs:
And here is how it looks if I pull it out slightly:
I can't just push it back in. Does anyone know how to fix this or what is wrong?
Old Oct 23, 2011 | 07:21 PM
HYDRUS's Avatar
I have the same problem!!! Happened to me one day on my lunch break so after work i went to the dealership and they told me 120 to fix. Its held in by clips inside the door.
Old Oct 23, 2011 | 11:36 PM
Tabris's Avatar
Not sure. Maybe taking off the door panel would help (they are not very hard to remove).
Old Oct 23, 2011 | 11:47 PM
speedracerg35's Avatar
there should be a torx bolt holding the lock assembly in place. you should be able to see it if you open the door and look above the door latch assembly. if it is missing, you need to replace it.
edit:
Old Oct 24, 2011 | 10:33 AM
dae's Avatar
dae
This happened on my passenger side and im assuming its the same on the driver side. I circled where the screw was on mine, and the arrow is where you should put your screw driver in to screw in the screw.
Driver's door lock/escutcheon coming out.. fix?-vd9ql.jpg
Old Oct 24, 2011 | 03:57 PM
cpufreak3's Avatar
Thanks, I'll take a look to see if the torx bolt is missing!
slider_ua
Jul 29, 2015 04:17 PM
apintojr
Jul 23, 2015 10:52 AM
emorehs
Jul 17, 2015 09:45 AM
si_driver
Jul 16, 2015 09:40 PM
