Changing my camber settings?
Old Oct 30, 2011 | 08:42 AM
saltyload's Avatar
Anyone know if there are any adverse affects to making all 4 wheels have the same camber and in such a way that the outside and inside of the tire wears evenly? Would 0 camber wear the outside more than the inside?
I don't race or track the car so I want the tires to last as long as possible, but still have good traction/handling.
Old Oct 30, 2011 | 08:56 AM
MADtotheA's Avatar
zero camber would mean that your tires are perfectly even. That is what you should be trying to achieve with a camber kit. You're daily driving will be fine with that.
Old Oct 30, 2011 | 09:04 AM
gary c's Avatar
Salty, if you get a four wheel alignment to OE specs your G won't have excessive tire wear unless you have some type of suspension failure.
Gary
Old Oct 30, 2011 | 07:26 PM
saltyload's Avatar
Gary
I thought OE specs have negative camber in the back? The inner part of my tires in the rear are definitely more worn than the outside. Last thing I want is unnecessary tire wear. Not sure of the fronts though.
Old Oct 30, 2011 | 08:21 PM
MADtotheA's Avatar
You need camber kits. A lot of people have camber issues on stock set ups.
Old Oct 30, 2011 | 08:33 PM
gary c's Avatar
I'm lowered and have the camber kit front and back, alignment is set to OE specs and my tires are wearing evenly. There is the slightest amount of negative camber but not enough to make your tires wear out prematurely.
Gary
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
shavedcrx
20 Inch
Aug 7, 2015 04:14 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
Soumilg
Jul 18, 2015 12:33 PM
nascarbuff17
Jul 16, 2015 10:23 AM
