I got troubles driving on freeway!!! (HELP!!)
Old Dec 22, 2004 | 02:51 AM
godlike0104's Avatar
I got 19" wheels with H-techs springs. But the problem now is that everytime i drive on the freeway. It scratches either my rear fender or the underbody exhaust. (im pretty sure its the back exhaust) Why is that? it only lowered 0.6/0.3 .
Does anyone else have the same problem like i do??
Old Dec 22, 2004 | 09:38 AM
GR8TG35's Avatar
Depending on the Offset you have for the rear wheels, you may be rubbing the tires when you compress the rear springs.....
You should see scuff marks on the rear tires if thats the case....
If so, have the fender lips "rolled" that should eliminate the problem......
Old Dec 22, 2004 | 10:34 AM
waijai's Avatar
i.love.gold
What are the specifications for your wheels?
Old Dec 23, 2004 | 11:20 PM
Gee Im Fast's Avatar
Yea, I would check my camber and roll the inner fenders if you have to. My friend had 19's on an Audi S4 and had to roll the fenders. Goodluck.
Old Dec 24, 2004 | 02:10 AM
19x9 front 19x10 rear with right offset sets up.
Old Dec 24, 2004 | 11:18 AM
kenchan's Avatar
Check the tire sidewall where it's rubbing (inner or outer). If inner, you'll want to
get a spacer to push out the wheel and new studs. If outer, you can half-*** it
by going to an alignment shop and asking for more neg camber on the rear for
clearance. Your tires will wear a little faster on the inter treads with more camber,
but as long as the toe is not far off, you should be fine.
Muski_G
Dec 1, 2023 11:11 AM
Calvin
Southern California
12
Oct 15, 2015 04:21 PM
bdnbfrank
Aug 17, 2015 02:09 PM
Felipe Gonzalez
Aug 16, 2015 10:02 AM
JMSABO
Aug 4, 2015 11:58 AM
