tire help
Old Nov 8, 2011 | 03:19 PM
GermanDrft's Avatar
tire help
will 255/35/19 work on 19in rays for the rears ??
Old Nov 8, 2011 | 03:42 PM
herrschaft's Avatar
yes
Old Nov 8, 2011 | 04:24 PM
GermanDrft's Avatar
alight koo. since there wider i should get better traction right ? thats what the guy at discount tire told me just want to make sure before i spend all this money on tires . ihave 245/40/19 right now
Old Nov 8, 2011 | 07:27 PM
4D05G35's Avatar
The contact patch on the 255 will be 10mm wider than the 245's.
Old Nov 8, 2011 | 07:50 PM
4DGS's Avatar
You'd be better off going 255/40 since the front is still probably the 225/45
Old Nov 8, 2011 | 10:30 PM
jstudrawa's Avatar
225/40 on the 19's in front. And I agree tho.
If you're going to 35 profile, go 265 or 275.
Old Nov 9, 2011 | 03:36 PM
N80's Avatar
N80
A wider tire can give you a wider contact patch but it can also introduce more sidewall flex which can have a negative effect on handling. So wider isn't necessarily better if handling is the primary issue.
Old Nov 9, 2011 | 04:03 PM
jstudrawa's Avatar
Completely agree. I just went 275 on Kumho's from 245 Nankangs, and the issue wasn't the width where traction was concerned, it was the tire brand.
If I had to do it over, I'm not 100% sure I'd still go 275. But I am enjoying the more robust look of the car from the rear, to be honest.
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
bananax
Wheels & Tires CDN
Sep 10, 2015 06:14 PM
philthethrilloh
Sep 9, 2015 01:25 AM
socaldavid
Sep 5, 2015 04:35 AM
